Wiper issue
Mars478
PostPosted: Wed Jul 09, 2014 7:14 am    Post subject: Wiper issue Reply with quote
Does my wiper motor need to be replaced? The video will show you everything you need to know about the symptoms. the 10mm bolt being removed does not make a difference on whether or not the wipers work properly.
https://www.youtube.com/watch?v=sel64dwcllQ
924, 82, 5 speed, dark red, 500 dollar special.
Daily: 99 ML320, 210k and still trucking.
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger
SilverGhost
PostPosted: Wed Jul 09, 2014 5:38 pm    Post subject: Reply with quote
Mine has the same symptoms. I'm guessing the fibre wormwheel is stripped in the region of the wiper park position. I've ordered a new motor / gearbox assembly.
"Priscilla" 1981 924 NA RoW auto, metallic blue
Ozzie
PostPosted: Fri Jul 11, 2014 7:26 am    Post subject: Reply with quote
gear worn out.
Its AUTO and its BLACK
Montego Black on black/red
Mars478
PostPosted: Fri Jul 11, 2014 7:40 am    Post subject: Reply with quote
Ozzie wrote:
gear worn out.
Had a hunch it might be that. Thanks.
SilverGhost
PostPosted: Sat Jul 19, 2014 12:44 pm    Post subject: Reply with quote
I've just fitted a new wiper motor/gearbox assembly.
The wipers move much, much faster than before.
They're just like real wipers now!
deborah5123
PostPosted: Wed Aug 06, 2014 3:17 pm    Post subject: Better Change Reply with quote
Based on the video, You must change your wiper to prevent damage.
Mars478
PostPosted: Wed Aug 06, 2014 4:09 pm    Post subject: Re: Better Change Reply with quote
Did you even watch the video? The wipers are brand new. That is not the issue.
CorsePerVita
PostPosted: Wed Aug 06, 2014 11:23 pm    Post subject: Reply with quote
No, that has nothing to do with it. Nothing.
the teeth inside of it probably look like this:
They have a bad habit of grinding them up if you have a lack of lubrication in there. The other cause is a huge amount of friction from things like the linkage binding or being very hard to move. The only fix is a new gear, or a new motor. Once it's worn down to that point you're done. I had a spare motor and swapped the gear over and then lubricated it, and while I was at it I dremeled all the rust off the generator bits and cleaned it up.
How to fix your wiper motor (and yes, it is the same for the 944 as it is for the 924)
Do not just fix or replace the motor, but lubricate that linkage while you're at it to prevent the next one from having friction issues as well Taken care of and lubricated properly, they should last years on end.
- 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
