Electronics and hot fuses/relays.
Mars478
PostPosted: Fri Jun 13, 2014 2:38 pm    Post subject: Electronics and hot fuses/relays. Reply with quote
My car has been working nicely, although lately I notice that it starts to sputter after an hour or so of driving. Through some research I've found that this may be due to the fuses and relays overheating, so today in my curiosity I felt around that area to see if it was hot and I literally burnt my finger and immediately got a blister. It was scorching hot, and I'm guessing the fuel pump isn't getting the power it needs which equates to the car sputtering. My wipers have been working on and off lately and today they just died in the rain. What's the best way to go about alleviating the electronic circuits so that they don't get so damn hot?
Thanks, sorry for posting two threads, they are two distinctly different issues.
924, 82, 5 speed, dark red, 500 dollar special.
Daily: 99 ML320, 210k and still trucking.
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger
brealytrent
PostPosted: Fri Jun 13, 2014 4:05 pm    Post subject: Reply with quote
Clean all your electric connections of corrosion by applying this stuff.
Heat is a sign of resistance, and a bad or dirty/corroded connection is at fault.
1977 Porsche 924 - sold
1980 Porsche 931 - sold
1984 Porsche 928 'S2' Euro - sold
2016 Ford Fiesta ST - sold
2009 Porsche Cayman
D Hook
PostPosted: Sat Jun 14, 2014 12:38 am    Post subject: Reply with quote
Moisture gets into the cabin of these cars so easily and causes severe corrosion on all the electronics connections. Clean every ground, etc you can possibly get your hands on. After I did mine, I found my temperature gauge no longer showed the high temps and stayed below the half mark all the time. Everything just started to work the way it was supposed to. I ended up pulling the entire dash out so I could get to every connection. Not hard to do and worth it.
'80 924 n/a SOLD
