jhattie
Joined: 29 Jul 2013 Posts: 40 Location: Yarmouth NS Canada
Posted: Fri May 30, 2014 9:24 am Post subject: Little HELP!! Fuel Leak, 1982 924 |
I seem to have a leak coming from up above the fuel pump in the rear, looks like a round plug with a rubber gasket around it.
Anyone have any ideas or thoughts? _________________ 82 924
04 Avant Ultra Sport Wagon 1.8T
07 Rabbit
lot of Jetta's |
jason c
Posted: Fri May 30, 2014 9:56 am Post subject: |
| Are you talking about the bottom of the tank where the feed line for the pump comes out? |
jhattie
Posted: Fri May 30, 2014 9:58 am Post subject: |
It looks like it, been reading and it may even be the fuel tank pick up filter. _________________ 82 924
07 Rabbit
lot of Jetta's |
jason c
Posted: Fri May 30, 2014 10:07 am Post subject: |
| It is. You'll have to drain the tank first. Pinch the line to the fuel pump with hose clamp pliers or needle nose vise grips with pieces of hose on the jaws to protect the hose from cuts. Remove the pump and drain the gas from the tank back into gas cans. Then R&R the seal. You can try to tighten it up without draining the gas or taking anything apart but if the seal tears you'll have a leak you can't stop. |
jhattie
Posted: Fri May 30, 2014 10:12 am Post subject: |
Thanks for the info, I'll put it up on the lift and give that a try. _________________ 82 924
07 Rabbit
lot of Jetta's |
jason c
Posted: Fri May 30, 2014 10:27 am Post subject: |
| Jus make sure you have something to pinch the fuel line shut so you can stop fuel flow if/when you need to. And make sure you have plenty of gas cans to put it in. |
larchie
Posted: Fri May 30, 2014 11:05 am Post subject: |
PN 928 201 187 02 Sealing Ring
Also, it goes without saying to filter the fuel drained. |
