title change, Swapped WUR, now what?
PostPosted: Mon Jan 06, 2014 3:29 pm    Post subject: Reply with quote
scriblz7 wrote:
as was said earlier you should definately check the fuel pressures
Dude, he can tell the fuel pressure is OK because the plate has resistance.
kcoyle
PostPosted: Mon Jan 06, 2014 11:26 pm    Post subject: Reply with quote
DITC conenction under dash? Probably not but it only takes a sec to check.
How "apart" was the car beforehand?
PostPosted: Tue Jan 07, 2014 12:17 am    Post subject: Reply with quote
MikeDanger wrote:
also after the engine started to at least idle, I pushed on the CIS plate a tiny bit and again the engine wanted to die
It might be from the honda dash
Sorry, could not resist
You're not supposed to press the CIS plate!
You're supposed to press the throttle and have no vacum leaks.
If it idles fine let it warm up a bit and then try to rev it...you might have a very rich mixture setting.
PostPosted: Tue Jan 07, 2014 6:56 am    Post subject: Reply with quote
And install a thermostat.
Ian89C4
PostPosted: Tue Jan 07, 2014 10:28 am    Post subject: Reply with quote
try unplugging the frequency valve, it sounds like the system pressure is off and the computer feels that it needs to enrichen it. Perhaps if you unplug the frequency valve you may be able to get her to run. But that is not a fix, you need to check the system pressure.
Even if the WUR was said to be able to work, did you check the Ohm resistance across the WUR? You can do that with the WUR in the car and start going about it that way. You can find the resistance in the Haynes manual.
Good luck!
Ian
Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala")
MikeDanger
PostPosted: Tue Jan 07, 2014 6:05 pm    Post subject: Reply with quote
Good luck!
Ian
Actually I think I did unplug the frequency valve and it stopped running.
I did check the WUR resistance, and it seemed with in range.
However I did use a spare intake i had which already had a Cold start valve in it, thats really the only difference I can think of.
Im going to do a throrough check and tests and if nothing makes a difference Ill try the DIY pressure tester.
MikeDanger
PostPosted: Wed Jan 08, 2014 6:59 pm    Post subject: Reply with quote
Ok well I went back out tonight and checked, didnt find a vacuum leak. even pulled one of the vacuum lines off the throttle and it kept running.
I played with the mixture screw on the CIS meter, and it seemed ok, but still giving it any throttle the engine would stumble and die.
Unpluged the frequency valve, Aux air, and Coldstart, made no difference.
BUT disconnecting the overboost connector made it stop.
I let the engine warm up and run for about 8-10min
I was going to start checking the injectors and Pulled the first one out, jumpered the fuel pump, but nothing happend?? I didn't hear the pump run, and when I pressed the meter plate nothing happened.
By then I was tired and cold.... and decided to go home.
So I have to see why the fuel pump didn't come on when I jumpered it. But im assuming it must be running when the car was on right?? (its a new fuel pump BTW)
One thing I just remembered; I opened one of the 2 spare WURs I had (before i installed it) But im not sure which of them it was. I wonder if I could have done any thing to damage it. However its pretty simple, didnt look like there was much to screw up. I didnt open the actual fuel valve part.
SO, sounds like its not getting enough fuel... BUT keep in mind before I swapped the WUR, it would rev just fine like nothing was wrong (until the engine warmed up)
hrmmmmmmm
dpw928
PostPosted: Thu Jan 09, 2014 1:24 am    Post subject: Reply with quote
Your problem may be caused by low system pressure. This can be caused by a defective/clogged relief valve, incorrect (low pressure) or defective fuel pump, partially clogged fuel filter or a plugged port between the relief valve and fuel distributor due to broken o rings on the relief valve.
Recommend you perform a pump volume test, and inspect the relief valve for o ring damage.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
PostPosted: Thu Jan 09, 2014 1:59 am    Post subject: Reply with quote
Thats weird dont you think?...why would they be connected if it runs with them dissconnected anyway?
If you pulled a vaccum hoose and it did not make ANY difference you surely have a vacum leak somewhere else.
Did you connect & secure the port UNDER the intake manifold?
MikeDanger
PostPosted: Thu Jan 09, 2014 5:31 am    Post subject: Reply with quote
yes the port under the intake is on and tight.
When I pulled the vacuum line it DID make a difference but not enough to kill the engine, which to me means that IF there was a vacuum leak, its still not enough to make the engine do what its doing.
Infact.... I would slighty press on the CIS plate and move the throttle at the same time (essentially manually tuning the mixture) but couldnt get it to do anything with open throttle.
MikeDanger
PostPosted: Thu Jan 09, 2014 5:42 am    Post subject: Reply with quote
Dennis
Um... which is the relief valve?
Fuel pump is new, as is Fuel filter (however the car came with out a fuel filter(the guy i got it from was trying to fix it and was waiting for a new filter, so basically the filter wasnt the issue)
PostPosted: Thu Jan 09, 2014 5:47 am    Post subject: Reply with quote
hmm...jump the pump, check how much comes out of the injectors.
dpw928
PostPosted: Thu Jan 09, 2014 7:32 am    Post subject: Reply with quote
The relief valve is in the fuel distributor. It is removed by unscrewing the brass hex bolt on the side. When you remove it, check the condition of the o rings.
Was the new pump made specifically for a CIS engine? There are a lot out there that are advertised for both the CIS and later L jet fuel systems but they don't have enough pressure. To test the volume, remove the inlet line to the fuel distributor, jumper the fuel pump at the 30 and 87 relay connection, then measure the amount of fuel pumped in 30 seconds. On a new CIS pump, it should be at least 1100 CC's.
Dennis
81 931 5 sp
78 928 5 sp Silver
MikeDanger
PostPosted: Thu Jan 09, 2014 9:53 am    Post subject: Reply with quote
Dennis
oh you mean the regulating valve. Ill check, but again It ran fine before I swaped the WUR.
dpw928
PostPosted: Thu Jan 09, 2014 10:15 am    Post subject: een Reply with quote
The relief valve could have been leaking but a defective (low control pressure) WUR would have compensated to a point. If the new WUR has raised the control pressure, a leaking relief valve would cause your current problem. If the relief valve looks okay and the new pump volume is sufficient, your next step should be a control/system pressure test.
Dennis
81 931 5 sp
78 928 5 sp Silver
Page 2 of 3
