Posted: Fri Dec 20, 2013 6:59 am Post subject: Head banging valves, a pictorial |
Well, the engine is on the stand, the head is off, plenty of bent stuff! I can't seem to compress the springs on the bent valves to remove them. Are these bent too badly to fix? The gouges on the pistons are not pretty either. I can replace those with some used Series II pistons.
Looks like the engine was burning a little oil too. Some oil at startup, but it went away.
 _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Posted: Fri Dec 20, 2013 8:14 am Post subject: |
Interesting. It appears that only the exhaust valves are bent.
Strongly recommend that you carefully inspect the rods. You might even consider replacing them.
Long after I disassembled the 941 motor, I was incredulous to find that one of the rods was quite noticeably bent...presumably the one from the #2 piston, which had the valve impressions and the floating valve guide. I'm guessing that the bent rod occurred from a previous timing belt failure and the previous owner only rebuilt the head, not bothering to inspect the lower end. _________________ erstwhile owner of just about every 924 variant ever made |
emoore924
Posted: Tue Dec 24, 2013 7:21 am Post subject: |
| Quote: | | It appears that only the exhaust valves are bent |
Sorry to say but I think all those valves are toast. Every single one has a smile on it Tough part will be removing them from the head without damaging it because you'll definitely want to reuse the head. I think it would be salvable. Like was mentioned, you'll want to check the rods too.
Sorry dude, a sad sight to behold. Did you figure out the reason for the failure? |
Posted: Tue Dec 24, 2013 7:47 am Post subject: |
The front crank bolt backed out and the upper and lower parts of the engine went their different ways! I had the 36-1 missing tooth EDIS bit in front of pulley, hiding that bolt. I ordered up a new 36-1 from Dan, so it'll be behind the pulley.
All the valves are out of the head; took some effort. _________________ '83 944 Track car.
