vacuum hoses
MikeDanger
PostPosted: Sun Dec 15, 2013 8:12 pm    Post subject: vacuum hoses Reply with quote
are standard silicone lines a suitable replacement for the braided ones? and plastic T's?
AND do I have to clamp them?
kcoyle
PostPosted: Mon Dec 16, 2013 1:27 am    Post subject: Reply with quote
I don't see why not. I use plain ol rubber lines and tee's from from the FLAPS. I'd clamp or wire any hoses that see boost. Probably wouldnt hurt to clamp them all if you're staying CIS.
Ozzie
PostPosted: Mon Dec 16, 2013 8:15 pm    Post subject: Reply with quote
pm sent
Its AUTO and its BLACK
Montego Black on black/red
snakoil
PostPosted: Mon Dec 16, 2013 10:01 pm    Post subject: Reply with quote
I use windshield washer hoses
1979 924 NA
PostPosted: Mon Dec 16, 2013 11:46 pm    Post subject: Reply with quote
I used a spool of 3mm silicone hose for the small stuff, and 1/2" elbows for those larger bits...
FYI, was recently pointed to these guys who sell metric hoses including some of the more annoying sizes...
https://www.belmetric.com/metric-hoses-c-14.html
(FWIW, the 3mm stuff I got in a spool from Summit)
