WUR removal
MikeDanger
PostPosted: Sun Dec 01, 2013 4:13 pm    Post subject: WUR removal Reply with quote
Can anyone tell me if the WUR can be removed with out removing the intake?
I can't seem to get to the bottom bolt.
Also I put my multi meter to the WUR and it measured at 25.5 Ohms, where as my other 2 were at 23.5 and 25.3 is that any indicaton that it might be good?
scriblz7
PostPosted: Sun Dec 01, 2013 6:33 pm    Post subject: Reply with quote
it can be removed without taking the intake off. keep trying!
Riley
79 924 n/a with gt body
15 VW GTI
scm924s
PostPosted: Sun Dec 01, 2013 7:52 pm    Post subject: Reply with quote
it's a bit easier if you remove the coil first.
1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold
MikeDanger
PostPosted: Sun Dec 01, 2013 9:19 pm    Post subject: Reply with quote
I did remove the coil, I removed almost everything in the area, except what I think is a coolant line, actually the coolant temp sensor is the main thing in the way so I can't get a ratchet in there. and regular allen keys are too short (for the bottom bolt, top is no problem)
kcoyle
PostPosted: Sun Dec 01, 2013 11:50 pm    Post subject: Reply with quote
It's possible. I just accepted the fact that there is too much crap under the hood and everything will be a PITA.
1982 931- Stock with MBC at 8psi
Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it.
larchie
PostPosted: Mon Dec 02, 2013 2:56 am    Post subject: Reply with quote
I wonder what were the results of the earlier tests recommended by ideola on your earlier thread? Those results would be a help for diagnosis.
I put my multi meter to the WUR and it measured at 25.5 Ohms ... is that any indicaton that it might be good?
Normally the heater coil of the WUR would have a resistance around 30 to 40 ohms, so there's not a problem there -- failure would read either none or infinite resistance.
One quick test if you don't have the test gauge setup yet -- I probably should have posted earlier -- is to disconnect the electrical connection to the WUR, run the fuel pump, and pull a vacuum from the lower fitting of the WUR to about 8 psi. If the regulator does not hold a vacuum above 3 or 4 psi after a minute, then the regulator should be rebuilt or replaced.
I don't know or remember your model year but on earlier CIS autos, (where the WUR doesn't have push value) as in a similar way pointed to in your earlier thread by ideola and 924 Racer, if the engine won't start when at operating temperature this is a common symptom of WUR failure.
MikeDanger
PostPosted: Mon Dec 02, 2013 8:18 am    Post subject: Reply with quote
Ok so HOW do I reach that bottom bolt??
dubrict
PostPosted: Mon Dec 02, 2013 12:18 pm    Post subject: Reply with quote
Last time I removed it I ended up throwing tools at mach 2 speeds into the wall until I broke down and pulled the intake. Since then I bought 5 spare intake gaskets because it's just not worth that level of rage. And I'm generally a pretty calm guy
1979 924 NA
2009 Chevy Impala
2005 Dodge Dakota
SilverGhost
PostPosted: Mon Dec 02, 2013 1:28 pm    Post subject: Reply with quote
I used a bench grinder to cut the longer leg off the correct size Allen key, fitted that into that size 1/4" drive socket which I then fitted to a ratchet arm. Then I held them all together with masking tape. Using this, removing and replacing that bottom screw is fairly easy, provided you have removed the coil.
"Priscilla" 1981 924 NA RoW auto, metallic blue
MikeDanger
PostPosted: Tue Dec 03, 2013 5:16 am    Post subject: Reply with quote
well if that temp sensor wasnt RIGHT behing the WUR it would be alot easier.
and id doesnt seem like I can remove the temp sensor either!
Brockoli
PostPosted: Tue Dec 03, 2013 6:08 am    Post subject: Reply with quote
I have done this twice I think, its a PITA but is doable without removing the intake manifold. Im pretty sure I used a standard allenkey too. All I really remember is my sore back as I was hunched over for awhile
I removed the coil, fuel lines, AAV (maybe not necessary but I wanted more room), vacuum lines.
To get the bottom bolt try using the allan key the long way and use pliers on the short end to get enough leverage to loosen the bolt.
maybeoneday
PostPosted: Fri Dec 13, 2013 7:36 pm    Post subject: Reply with quote
I just did it not that long ago with a long allan key that has an end that allows you to attack the bolt at a slight angle, I was having major problems getting to it with a normal allan key also.
PostPosted: Fri Dec 13, 2013 9:32 pm    Post subject: Reply with quote
WUR removal/adjustment is simple
OK, I cheated
txjake
PostPosted: Sat Dec 14, 2013 12:48 am    Post subject: Reply with quote
another thread that makes me happy that I converted to Webers.
1978 924, aka The Red Rocker
MikeDanger
PostPosted: Sat Dec 14, 2013 5:50 pm    Post subject: Reply with quote
yeah, theres no way its comming off with out removing the intake.
I was able to get an allen on the bottom bolt. and I THINK i cracked it. But i barely have room to move and I now cant tell if im turning the bolt at all, or just miving it back and forth or even engaing it now.
