Dluney
Joined: 16 Nov 2002 Posts: 25 Location: Sugar Hill,GA.USA
Posted: Sat Nov 16, 2002 1:13 pm Post subject: |
dgz924S I have an 87 924S SCCA ITS car for sale. I crunched the right front the last time out, so I am discounting the car as is to $9,500 or will sell repaired and race ready for $11,500. Attached is the replacement cost for all of the componants required to build the car(not counting ANY of my labor). The car is a consistant top 5 in the SE ECR (enduro series). I would consider selling just the motor and gearbox, or the motor/gearbox/non sunroof partscar.
Replacement costs
1987 924S Non sunroof tub $1,800.00
Mig/Tig 1.5 x.120 DOM 6 point full roll cage $1,800.00
1988 spec ITS engine by Mark Womack of Sunbelt (Builder of 12+ national championship SS, EP and World Challenge winners engine passed ARRC teardown with no issues. Milledge oil pan. 11.5 hours since rebuild $4,500.00
Custom Koni double adjustable front struts with aluminium treaded collars $800.00
Eibach spring with Ground Control camber plates. $375.00
New front steel control arms with welded roll bar mounts $80.00
Weltmiester adjustable bars with adjustable aluminum links(fr). $820.00
New radiator. $225.00
25 row SETRAB oil cooler plumbed with turbo oil filter housing. $300.00
Custom Aluminum catch tank with aeroquip lines. $100.00
New clutch hydraulics. $75.00
Bursch header. Dynomax race muffler $325.00
New wheel bearing (front and rear) $125.00
All new CV joints, packed with GKN (ChampCar) grease. $225.00
Manual steering rack with new tie rods and boots. $300.00
Braided brake lines. PFC pads $250.00
New brake rotors (F and R) $210.00
Tilton adjustable (lever type) brake bias $75.00
30mm gun drilled torsion bars $300.00
Custom Koni 3011 double adjustable (IT legal smooth body) $900.00
Transaxle has shimmed LSD, short 5th gear and 4.1 final drive. $1,700.00
10 lb fire system. Kill switch. $350.00
Butler custom "Pro" series aluminum seat. $350.00
Camlock belts, Mesh window net. $250.00
Momo suede wheel with Racetech quick release $125.00
10 Late offset 15 X 7 phone dials, 4 924S phone dials 15 X 6. $1,050.00
Guards Red Paint $800.00
Parts Car $750.00
Total spent $18,960.00
dluney@checkfree.com _________________ David Luney
87 924S SCCA ITS |
