Larger 86mm airflow meter, HP improvement ? -with pictures-
PostPosted: Thu Oct 24, 2013 11:16 pm    Post subject: Larger 86mm airflow meter, HP improvement ? -with pictures- Reply with quote
I still have two larger airflow meters that came with the Willibald 931 engine.
Will this be of any benefit (HP improvement) ?
The 931 (left) one is 76mm valve, the Willibald ones are 86mm.
Last edited by Dutch924-racer on Fri Oct 25, 2013 5:11 am; edited 2 times in total
PostPosted: Fri Oct 25, 2013 2:10 am    Post subject: Reply with quote
For the turbo, I suspect that the larger air flow meter is a benefit. For an NA, the area of the throttle body is probably the restriction rather than the air flow meter.
1981 924 Turbo sold
1982 924 Turbo sold
PostPosted: Fri Oct 25, 2013 5:59 am    Post subject: Reply with quote
Would be keen to see the results of this, and bag one of those myself as I reckon mine could do with more airflow. What car is the 86mm version from?
PostPosted: Fri Oct 25, 2013 4:41 pm    Post subject: Reply with quote
It looks like a Mercedes unit, there are no numbers on it.
It also had a different WUR, I will post the number of that this weekend.
PostPosted: Fri Oct 25, 2013 4:51 pm    Post subject: Reply with quote
merc or 928
dpw928
PostPosted: Fri Oct 25, 2013 10:50 pm    Post subject: Reply with quote
Please keep in mind that a larger venturi will result in slower air movement past the air sensor plate and may cause the engine to run lean.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
gegge
PostPosted: Mon Oct 28, 2013 5:36 pm    Post subject: Reply with quote
The length of the lever from the centre of the plate to the pivot is the same? The vacuum of the engine will pull the larger area harder and rise the plate higher for every given rpm if you donīt compensate with higher systempressure.
Measure the length of the lever from centre of the plate to the pivot and multiply with the area and divide with the length from the pivot to the plunger of the fuel distributor. It is the same for 924 and 931, and probably for all 4-cyl CIS cars using the same fuel systempressure.
It is a delicate trade-off. High pressure will cause restriction, but so does a small area.
Carl Fredrik Torkildsen
emoore924
PostPosted: Mon Oct 28, 2013 11:19 pm    Post subject: Reply with quote
Ok, I'm going to take the low road here and say if it works it will be dumb luck. The whole CIS setup is a *system* where all the parts are designed to work together; AFM, WUR, TB, turbo, manifolds, injectors, displacement, all of it. You change out one part without considering the rest of the design and you can put the whole system out of kilter.
Yes, it *might* work, but the they don't call it German engineering for nothing...
PostPosted: Tue Oct 29, 2013 7:18 am    Post subject: Reply with quote
+1, the shape of the bowl is a essentially a "hardware" engine map designed for a specific engine. If you want more fuel at a given load you can modify the metering slots in the fuel distributor.
