lemons 924S rear swaybar or not for NH loundon track
Should we add rear swaybar?
Yes we should!!!
100%
 100%  [ 4 ]
No way for the rear sway!!!
0%
 0%  [ 0 ]
Total Votes : 4
pyropete125
PostPosted: Mon May 06, 2013 4:41 am    Post subject: lemons 924S rear swaybar or not for NH loundon track Reply with quote
Hi all,
we have a 924S with a 2.5 NA lemons racer.
here is our setup:
stock front sway bar, koni adj and stiff spring coil overs.
rear konis all the stiff- needs more shock as our experienced driver says.
I have a stock rear swaybar setup off a 944 NA that I could put on. will that help or hurt? No LSD
I have been told by non 924/944 racers no dont add it since it will unload the wheel on turning exit [which is a problem now]
Thanks,
pete
hayeslewis
PostPosted: Tue May 07, 2013 10:47 am    Post subject: Reply with quote
It's pretty easy to unhook it, so you could put it on and be able to try it both ways.
Hayes Lewis
1979 924 FP/DP/ITB? "Bibi"
1979 924 ITB #6 "Pam"
2007 Armada
2013 Hyundai Elantra
19?? Cheap Chinese Pedicab with a 1.2HP electric motor "The MULE"
Multi Use Lazy-ass Electric vehicle
pyropete125
PostPosted: Wed May 08, 2013 10:04 am    Post subject: Reply with quote
I think that is what we are going to do tray with and try without.
pyropete125
PostPosted: Mon Jul 22, 2013 12:32 pm    Post subject: Reply with quote
I figured that I would post results finally.
Saturday nice weather then rain and we added it after racing Saturday night, since the wet would make it even more likely to over steer.
Sunday nice all day and the car felt better everywhere! up hill down hill, stopping, inside out side, just everywhere we were all more confident.
Now the kicker is that we were 0.2 seconds slower the second day with the sway bar on. But since we all felt it as a confidence builder and a better drive we are going to leave it on.
Pete
PostPosted: Mon Jul 22, 2013 4:58 pm    Post subject: Reply with quote
Loudon is an oval of some sort? YES you need the rear bar, but you can weight bias the car by raising the ride height on the problem wheel. Easy!
  • Weisse (1987 924S) - Turbo S3
emoore924
PostPosted: Tue Jul 23, 2013 11:29 am    Post subject: Reply with quote
Are you running just the oval or the road course too?
FJ40Jim
PostPosted: Tue Sep 17, 2013 2:48 am    Post subject: Reply with quote
I'm not racing a 924 yet, but I do race 24HoL.
The loudon track is run as a roval, 1/2 on the oval and 1/2 outside the oval on a road cource.
There will be another 24HoL race at Loudon 26-27 October.
