1.8T 924
Goto page Previous  1, 2
steve924
PostPosted: Fri May 10, 2013 6:40 am    Post subject: Reply with quote
The cylinder spacing is approx 87mm, the engine is much shorter than the 2.0na
Steve
Porsche 924 na
porsche 924 1.8t
steve924
PostPosted: Fri Jun 07, 2013 7:07 am    Post subject: Reply with quote
Had the engine running with a stand alone ecu and first impressions are really good , still needs lots to make it road worthy.
The clutch is nice and light and very smooth, the 944 s2 gearbox is really quiet and smooth with a much taller 1st gear which makes all the difference.
The engine is so quiet and smooth and rev's so freely, there is no lag at all with the standard KO3S turbo, its only running a 210 - 220 bhp map but I'm going to build another engine (they are really cheap over here) for around 300bhp, which is tame for one of these engines as i want a flexible reliable motor rather than a 400bhp + drama queen!
I'll make a rather boring video if i get a moment at the weekend to prove it runs
Porsche 924 na
porsche 924 1.8t
PostPosted: Fri Jun 07, 2013 11:34 am    Post subject: Reply with quote
Jealous.
steve924
PostPosted: Sun Jun 09, 2013 7:49 am    Post subject: Reply with quote
Not a very interesting video, excuse all the yellow cable ties run out of black they will be changed, still loads to do but its alive at last
http://youtu.be/9pb0p1HPeHE
Porsche 924 na
porsche 924 1.8t
Horizonblue
PostPosted: Wed Jun 12, 2013 4:15 pm    Post subject: Reply with quote
Congrats with the running car!
I still have some work, before my 6 cyl 924 is running.
Euro 924, 1976
/P.G. Andersen
steve924
PostPosted: Thu Jun 13, 2013 6:57 am    Post subject: Reply with quote
Thanks, I think your 6 clylinder will be a really nice cruiser and sound cool
Heres my electric power steering column
its a vauxhall Corsa C column, the main work involved is the steering shafts which has to be done properly as its life and death.
The upper column on the corsa is a splined removable shaft so you can weld the 924 column to the corsa upper shaft (it was welded pinned and a outer sleve welded for strengh) which then means you can use the outer column with the steering lock and column mount etc.
The lower shaft is much simpler as in the pic
A very strong mounting bracket was made to fix the column to the car. and the columns ecu was relocated to the columns motor to fit under the dash
To run the column it needs 2 signals, one pulsed telling it the engines running and another telling it the cars speed, to simulate these signals there are people who make a little box (ebay)which means you can manually adjust the weight of the steering.
Or you could use a abs sensor on a wheel to make it speed sensitive, I do have the vauxhall part no for the abs signal amplifier somewhere.
It has to be said the system works better with wider tyres, and getting it adjusted to give good feedback through the steering wheel takes a bit of experimenting and it does loose some feel but it makes the car alot easier on the narrow twisty roads where i live
Porsche 924 na
porsche 924 1.8t
steve924
PostPosted: Mon Aug 12, 2013 6:55 pm    Post subject: Reply with quote
Been using the car for work with low boost as it needs mapping. Next will be to relocate the ecu (on the front left) to under the dash and tidy up the engine bay.
The car is brilliant and fast even in its current tune
Porsche 924 na
porsche 924 1.8t
beario
PostPosted: Mon Aug 19, 2013 8:00 am    Post subject: Reply with quote
Fantastic mate...where abouts are you in uk...pm if you want cheers...
theres no replacment for displacement....V8
steve924
PostPosted: Tue Aug 27, 2013 11:39 pm    Post subject: Reply with quote
Lurking in kent
Porsche 924 na
porsche 924 1.8t
Horizonblue
PostPosted: Thu Oct 31, 2013 10:18 pm    Post subject: Reply with quote
When do you take the car out for a spin, with a camera in the backseat
Euro 924, 1976
/P.G. Andersen
PostPosted: Tue Dec 10, 2013 12:17 pm    Post subject: Reply with quote
Any pictures of the transmission tunnel mods from the inside?
steve924
PostPosted: Tue Jan 07, 2014 6:09 am    Post subject: Reply with quote
Been a while since updating this thread,
I'll look for some photos of the tunnel and a video is on the todo list.
the car has been on the road for 6 months or so running pretty much unchanged but done a few more bits, really enjoy driving and not too bad on fuel and after a couple of thousand miles havn't had to put any oil in it etc. The paint work is truly terrible and ists still running in the low 200 bhp's
Finished moving the ecu to under the dash and getting rid of the patch work wiring, it now has the ecu, relays and fuses for the engine all in one place and a dedicated loom for the engine thats all plug and play now.
the relays live under the ecu with a removable cover and a bracket to stop them working loose, ats all made from aluminium.
the engine bay is much neater without the wiring all over the place
I've also set up the triple map option on the ecu so can now run 3 seperate maps selectable from a dash switch, power loads of boost :twisted: , economy with little boost and a safe map incase a sensor fails.
Next is a full 3 inch exhaust (Subtle i hope) shorter boost pipe run and sort out the cooling hoses. Also got to start building another engine and then eventually some paint (maybee)
Porsche 924 na
porsche 924 1.8t
steve924
PostPosted: Mon Apr 21, 2014 2:21 am    Post subject: Reply with quote
Been playing with the car, now has the turbo from a 225/240 bhp audi tt and tubular manifold, the flange needed modding etc, this set up should top out around 270-280bhp which is more than enough if 200bhp is anything to go by in these little cars
also sorted the boost pipes shortening the pipes by over 12"
next is a full 3" exhaust and an oil catch tank
Porsche 924 na
porsche 924 1.8t
markrnorton
PostPosted: Tue Jul 22, 2014 7:15 am    Post subject: Reply with quote
This is a great thread and conversion
Who's mapping the emerald ecu for you ?
Brockoli
PostPosted: Tue Oct 10, 2017 7:27 am    Post subject: Reply with quote
How much room is there in between the turbo and the frame rail?
Do you think a larger turbo would fit?
Page 2 of 2
