Hatch Strap Install
PostPosted: Fri May 03, 2013 1:53 am    Post subject: Hatch Strap Install Reply with quote
The brackets: Flat base attaches to factory latch pin mounts, bent piece hugs curves of the hatch. Does not touch body!
Pegasus Racing generic t handles.
T handles slip over the hooks, and don't need to be attached, making them easily replaced.
Factory mounting points (M6).
Installed.
Receiver riveted to body.
Done! No hatch. . ."incidents" on track.
txjake
PostPosted: Fri May 03, 2013 3:36 am    Post subject: Reply with quote
very cool. rattles?
any way of getting dimensions on the brackets? or buying a pair?
1978 924, aka The Red Rocker
PostPosted: Fri May 03, 2013 5:00 am    Post subject: Reply with quote
Rasta da man! I want some for my two cars.
1979 924 NA race car
1982 924 Turbo almost a PoS
PostPosted: Fri May 03, 2013 5:23 am    Post subject: Reply with quote
Pegasus Auto Racing T handles:
https://www.pegasusautoracing.com/productdetails.asp?RecID=769
Available in Small, Medium and Large.
PostPosted: Fri May 03, 2013 5:36 am    Post subject: Reply with quote
Large pictured above.
PostPosted: Fri May 03, 2013 8:37 am    Post subject: Reply with quote
Did you fab the brackets in the first picture?
PostPosted: Fri May 03, 2013 10:01 am    Post subject: Reply with quote
I did fabricate the brackets. Considering a small run. . .stand by whilst I figger.
PostPosted: Sat Aug 24, 2013 12:16 pm    Post subject: Reply with quote
Summit racing carries them too. Rastaman your awesome dude.
PostPosted: Tue Dec 31, 2013 9:31 pm    Post subject: Reply with quote
Put me down for one pair for personal use, more if you're interested in a reselling arrangement.
txjake
PostPosted: Wed Jan 01, 2014 12:50 am    Post subject: Reply with quote
I'd take a pair also......
PostPosted: Wed Jan 01, 2014 3:45 am    Post subject: Reply with quote
I'd take two sets.
PostPosted: Sun Aug 03, 2014 5:05 pm    Post subject: Reply with quote
I followed suite and made a pair. I had predrilled holes I didnt
fill when I painted so I went rogue.
Great idea dude.
