dipstick seal?
xanderdeg
PostPosted: Thu Apr 04, 2013 6:27 am    Post subject: dipstick seal? Reply with quote
My dipstick has no seal so it leaks oil out of the hole as I drive. Does anybody know the part number for the seal? Or something I could use as a replacement?
!tom
PostPosted: Thu Apr 04, 2013 3:32 pm    Post subject: Reply with quote
Sounds like you've got bigger problems. Your crankcase should be vented to your airbox. Your crank breather must be blocked in order for you to be leaking oil out around your dipstick.
78 924 NA
5-lug
xanderdeg
PostPosted: Thu Apr 04, 2013 3:35 pm    Post subject: Reply with quote
I hooked up a brand new breather hose just 2 months ago! I guess I'll check it again for blockage...
Duncan
PostPosted: Thu Apr 04, 2013 10:01 pm    Post subject: Reply with quote
Can I ask where you got the breather hose?
These are no longer available here, I tried many different sources.
It is a very special hose with a small restrictor inside.
1983 NA Alpineweiss since 2001
Peugeot 205 Generation
PostPosted: Fri Apr 05, 2013 1:31 am    Post subject: Reply with quote
Good hardware store should have an oring that will fit, if you walk in with it.
Oh, and +1 on your excessive crank pressure. Compression test may be in order.
xanderdeg
PostPosted: Fri Apr 05, 2013 1:37 am    Post subject: Reply with quote
... I made my own with some fuel hose and PVC elbow joints... Couldn't find one either so I just did a DIY.
xanderdeg
PostPosted: Fri Apr 05, 2013 1:49 am    Post subject: Reply with quote
Compression test to be conducted this weekend, fingers crossed....
924aussie
PostPosted: Sat Apr 06, 2013 9:40 pm    Post subject: Reply with quote
Not sure, but havent I read somewhere that your dipstick has to have a good seal for the EFI to work properly ??
Alan
green 924 .. 1980 rego 924PSH
1998 Mopar Neon ... sick
2003 Challenger / Montery 4WD
1995 Hyundai Scoupe ... sold
1980 Fire truck Sold
xanderdeg
PostPosted: Sun Apr 07, 2013 3:30 am    Post subject: Reply with quote
Well I guess its a good thing that I don't have efi
Ozzie
PostPosted: Sun Apr 07, 2013 7:41 am    Post subject: Reply with quote
Oil breather hose can be any oil resistant hose, just jam a piece of broom handle in it with a 6mm hole in the centre.
Its AUTO and its BLACK
Montego Black on black/red
