Engine Valves.......Noisy or just me????
loddyjr
PostPosted: Wed Feb 27, 2013 2:14 pm    Post subject: Engine Valves.......Noisy or just me???? Reply with quote
Appreciate anyones feedback on the attached video! Is the valve noise excessive or is it just me.....
http://youtu.be/2Pzit5jIrY4
PostPosted: Thu Feb 28, 2013 1:58 am    Post subject: Reply with quote
They don't sound horrible to me, but it takes less than two beers and a ten dollar gasket to check them.
emoore924
PostPosted: Sat Mar 02, 2013 11:14 am    Post subject: Reply with quote
Probably worth checking. They sound a little noisy.And the sound seemed to be changing a little which might indicate an oiling tube problem or a follower that's rotating (normal) but has some wear (not normal). Take the cover off and check the lash and the cam lobes and the oiling tube and the followers...
PostPosted: Sat Mar 02, 2013 12:52 pm    Post subject: Reply with quote
Or an exhaust leak. In any case adjust your valves at every other oil change, that's what I always did on my 2.0 cars.
PostPosted: Sat Mar 02, 2013 9:23 pm    Post subject: Reply with quote
They do sound a noisy..but cell phone recordings are shit and you cant really tell.
This is recorded with my iphone...you can hear the engine at the end of the video...mine is not so noisy...so check and adjust your valve cleareances.
http://www.youtube.com/watch?v=gItO_q0sQZ4
