high idle and missing
crow.magnum
PostPosted: Sun Feb 17, 2013 3:06 am    Post subject: high idle and missing Reply with quote
hi, ive got a 1980 931 .
its not been driven for a few month. so today i took it out.
started first time , but it idles at 1200 rpm and when i drove it it had a severe missing problem .
any ideas where to start??
Nein37
PostPosted: Sun Feb 17, 2013 3:41 am    Post subject: Reply with quote
Vacuum lines. Check them all.
1981 931 CGT replica, OEM CGT intercooler, .8 BAR WG spring, GTS Headlights, Innovative Wide band A/F, A/C delete, 16" Fuchs, Weltmeister 200lb lowering springs, Bilstein HDs front, Koni Sport rears.
crow.magnum
PostPosted: Sun Feb 17, 2013 7:09 pm    Post subject: Reply with quote
Ok whats the best way to find an air leak
crow.magnum
PostPosted: Sun Feb 17, 2013 7:54 pm    Post subject: Reply with quote
dpw928
PostPosted: Mon Feb 18, 2013 2:07 am    Post subject: Reply with quote
Since it is missing and has a high idle, I would check the intake to cylinder head gaskets first. Try spraying a mist of water on each vacuum area and listen for a change in the idle and look for white exhaust smoke.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
PostPosted: Mon Feb 18, 2013 3:01 am    Post subject: Reply with quote
Best way to find intake leaks is with a smoke machine. Worth a couple of bucks to have a mechanic do this.
crow.magnum
PostPosted: Tue Feb 19, 2013 1:03 am    Post subject: Reply with quote
Whats going on with this car
I checked for air leaks , I tweeked the intake bolts all were fine. Started the car it idled 1000 rpm. Took it down the road missed real bad turbo would not kick in just made some kind whineing noise . Got home car idled 1500 rpm flipped bonnet had steam coming up for exhaust area and the battery has started to leak acid . Are these all connected or am I on a a roll of bad luck .
dpw928
PostPosted: Tue Feb 19, 2013 1:23 am    Post subject: Reply with quote
The battery may have an internal short which could cause low voltage and poor spark. Was the steam from the exhaust caused by the battery acid?
Dennis
81 931 5 sp
78 928 5 sp Silver
crow.magnum
PostPosted: Tue Feb 19, 2013 1:37 am    Post subject: Reply with quote
No the battery is on the oppisite side
dpw928
PostPosted: Tue Feb 19, 2013 1:55 am    Post subject: Reply with quote
Forgot about the right hand drive. Are there any heater hoses in the vicinity of the exhaust that could be spraying coolant?
Dennis
81 931 5 sp
78 928 5 sp Silver
crow.magnum
PostPosted: Tue Feb 19, 2013 2:07 am    Post subject: Reply with quote
No coolant hoses that im a whare of only the turbo and a breather hose
dpw928
PostPosted: Tue Feb 19, 2013 2:21 am    Post subject: Reply with quote
You may want to check for an oil leak at the cam cover or the oil line feed to or from the turbo.
Dennis
81 931 5 sp
78 928 5 sp Silver
PostPosted: Tue Feb 19, 2013 3:08 am    Post subject: Reply with quote
Did you check the charge pipe coming directly off the turbo? Pull up on it and make sure the bracket hasn't come loose or broken.
crow.magnum
PostPosted: Tue Feb 19, 2013 3:24 am    Post subject: Reply with quote
Its all tight and secure
kcoyle
PostPosted: Tue Feb 19, 2013 4:02 am    Post subject: Reply with quote
crow.magnum wrote:
Got home car idled 1500 rpm flipped bonnet had steam coming up for exhaust area (
Did it smell like coolant or oil? Hopefully it didn't smell like fuel, which could explain the poor running.
Before you posted this I would have said maybe the AAV is stuck open.
1982 931- Stock with MBC at 8psi
Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it.
