vikingfan1974
Joined: 24 Nov 2012 Posts: 20 Location: Plainview, Minnesota
Posted: Sat Jan 19, 2013 12:03 am Post subject: This blows |
82 NA...Blowing hot air constantly thru the vents even with temp controls off....ideas???? _________________ 82 924 N/A
88 924s |
Posted: Sat Jan 19, 2013 2:01 am Post subject: |
broken controls or broken valve. _________________ https://www.the924.com |
vikingfan1974
Posted: Sat Jan 19, 2013 2:09 am Post subject: |
Sorry for the ignorance...but which valve might it be? _________________ 82 924 N/A
88 924s |
DOCO
Joined: 04 Aug 2006 Posts: 1111 Location: Keswick Ontario Canada
Posted: Sat Jan 19, 2013 5:03 am Post subject: |
the valve would be the one under the hood in the heater hose .Its a plastic valve close to firewall,will have a small lever arm with a cable thats controlled by heater slide inside. There is a pic in my webber install of it.Dam i should finish that job!!! _________________ Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
vikingfan1974
Posted: Sat Jan 19, 2013 5:17 am Post subject: |
Thanks, I do have a Heater control valve that I have not put in yet, it's just that it has gotten alot worse....So hopefully replacing that will solve this issue! _________________ 82 924 N/A
88 924s |
joejax
Joined: 02 Dec 2009 Posts: 919 Location: Jacksonville,FLA,USA
Posted: Sat Jan 19, 2013 2:07 pm Post subject: |
I thought that was normal.... _________________ I got nothin'
Uhhh...you got any pics? |
