Mexico924
Posted: Sat Mar 03, 2012 11:18 am Post subject: My 77 starts right away idles rough and has no power at all |
Hello every body
I will give you the known facts
It has spark in all the cylinders and has compression as well.
Any ideas???
Regards
Eduardo _________________ 1977.5 924 NA
1971 911 T sunroof in restauration process
1962 356 notchback (sold) |
Harm
Posted: Sat Mar 03, 2012 7:25 pm Post subject: Re: My 77 starts right away idles rough and has no power at |
1st. Check for vacuum leaks between head and airbox, then
2nd. Correct the timing (Turn the spark distributor)
HTH
Edit01: Subject would do in General Discussion if yours has no Turbo  _________________ Porsche 924 NA 1982 LY7A/A3A3 _ Greater driving pleasure never harmed anyone. |
Khal
Posted: Sun Mar 11, 2012 1:26 pm Post subject: Re: My 77 starts right away idles rough and has no power at |
| Harm wrote: | Edit01: Subject would do in General Discussion if yours has no Turbo |
+1
And I always suspect the fuel pumps (and/or system as a whole). But...
Wrong forum. This one is for 924 Turbos only (A.K.A. 931).
Not a problem, you'll just get a better response posting here.
Perhaps the mod's would be kind enough to shift it? _________________ '80 924 Turbo |
Mexico924
Posted: Mon Mar 12, 2012 11:32 am Post subject: |
Thanks Harm aun Khal
I'll be looking for the things you mentioned
Thanks again
