fuel octane uk
doug60
PostPosted: Mon Feb 06, 2012 1:52 am    Post subject: fuel octane uk Reply with quote
Hi,
The 924 1984, should run on 98 octane, Now you can't get this, I've been running on 95. Should you advance the timing to compensate for this ? and by how much. I put the lead additive in.
Thanks
DB
Horizonblue
PostPosted: Mon Feb 06, 2012 3:55 am    Post subject: Reply with quote
You should not advance the timing, but retard to approx 5° BTDC.
I did that on mine, and it cured a lot of engine noise under acceleration (ignition knock)
Power loss; maybe it can be measured, but I can't feel it.
You can also just retard the timing, until there is no ignition knock, then it should be fine to run the car. It will take some test-rides and adjusting.
Euro 924, 1976
/P.G. Andersen
ptheskil
PostPosted: Mon Feb 06, 2012 7:03 pm    Post subject: Reply with quote
You don't need lead additive for valve seat protection on the 924 engines. It will help with the octane problem though. But...did you know that the so-called "super unleaded" fuel in the UK is around 98RON - it varies a little from supplier to supplier but Shell Vpower and Sainbury's own brand super unleaded are 99RON IIRC. I run Sainsbury's and Vpower in my turbo without any trouble.
The extra money you spend on fuel will be partly compensated for by not needing to use an (expensive) additive and the improved fuel consumption you will get by not running with retarded ignition. Spend the cash on a dose of fuel injection system cleaner from time to time which is very worthwhile for engines with K-Jetronic.
1981 931 series2 Euro spec
PostPosted: Mon Feb 06, 2012 7:24 pm    Post subject: Reply with quote
When i drove my 79 n/a i never noticed any difference when i switched from 95 to 98 or the opposite. Did drive on 98 on the track most of the times though just for the extra margin. The ignition was regulary checked and adjusted to specifications.
scm924s
PostPosted: Tue Feb 07, 2012 12:20 am    Post subject: Reply with quote
The 924n/a and the early 924S are designed to run 95 octane in UK, the only one requiring 98 octane is the last 924S with the 160BHP motor. No fuel additives are required.
Horizonblue
PostPosted: Tue Feb 07, 2012 2:42 am    Post subject: Reply with quote
Really?!
When I ran on 95 octane, and 10°BTDC, my experience was a lot of ignition knock, during acceleration, especially around 3000 RPM.
I set it to 5° BTDC and that cured this terrible noise. I have never had the distributor checked, to see if it advances like it should, nor have I any idea on how good the injectors worked.
Today it doesn't really matter, the engine is out of the car, and I'm installing a 1984 engine with EFI (VEMS probably)
Euro 924, 1976
/P.G. Andersen
doug60
PostPosted: Wed Feb 08, 2012 2:52 am    Post subject: fuel additive Reply with quote
Thanks for the replies and info.
Why don't you need a lead additive ?, did the 924n/a come with hardened valve seats as standard !!
DB
Ozzie
PostPosted: Wed Feb 08, 2012 6:14 am    Post subject: Reply with quote
yep
Its AUTO and its BLACK
Montego Black on black/red
!tom
PostPosted: Wed Feb 08, 2012 9:39 am    Post subject: Reply with quote
Especially considering the North American market cars at least had catalytic converters, which are destroyed by lead in fuels and hence require unleaded.
78 924 NA
5-lug
