beario
Joined: 03 Nov 2002 Posts: 139 Location: st albans/cornwall
Posted: Wed May 27, 2009 4:30 am Post subject: lexus 1uzfe |
anyone ever tried doing this...would be great reliable hp...i have the engine in my garage...was going to maybe use the porshe flywheel with the lexus/mr2 centre(same bolt pattern) and have it welded in at a machinists,and then just make an adapter plate to bolt the 2 together,then i can use the porshe b/housing and clutch /starter set up...any thoughts...pics... _________________ theres no replacment for displacement....V8 |
beario
Posted: Thu May 28, 2009 4:50 am Post subject: |
1uzfe is the lexus ls 400 v8 4 cam 32 valve v8...just measure it to be
27" wide
28" long
26" tall... _________________ theres no replacment for displacement....V8 |
beario
Posted: Sun Jul 04, 2010 6:44 am Post subject: |
anyone... _________________ theres no replacment for displacement....V8 |
powaw
Posted: Wed Jul 07, 2010 9:55 am Post subject: |
you'll just have to try it man, do you already have a donor Porsche to compare dimensions? I looked at some of those engines and the Audi ones just seemed like less work. It all depends on how determined you are. _________________ currently: 1987 944 NA 5spd, 250 lb hyper coils, 27 mm t bars, koni yellows, 968 m030 bars,,RE ball joints, full delrin
future: audi I5 20VT
follow Nina at Nina's 20VT |
beario
Posted: Tue Jul 20, 2010 8:32 am Post subject: |
anyone thought of this... _________________ theres no replacment for displacement....V8 |
beario
Posted: Sun Oct 31, 2010 9:01 pm Post subject: |
does not work way way way to wide to much fab work...gave up... _________________ theres no replacment for displacement....V8 |
xEcUtEr
Joined: 11 Apr 2008 Posts: 30 Location: Lisbon - Portugal
Posted: Thu Jan 12, 2012 2:46 am Post subject: |
Back from the grave with this topic..
Found a 1UZ-FE complete Engine at a good price...
it wont fit on a 1979 924??
Regards
Hugo _________________ 79' 924 2.0 @ Estoril Track |
beario
Posted: Tue Jan 17, 2012 6:48 am Post subject: |
yes it does fit..i have just got a 1uz fe vvti to put in my next 944...go to lextreme there is a guy that just fitted one in his 944... _________________ theres no replacment for displacement....V8 |
