New GTS headlight conversion kit available NOW page 10
Goto page Previous  1, 2, 3, ... 14, 15, 16  Next
GTS headlight conversion kit?
I am interest in a kit or parts
63%
 63%  [ 39 ]
I will thing about it
21%
 21%  [ 13 ]
Not interest
14%
 14%  [ 9 ]
Total Votes : 61
PostPosted: Thu Dec 29, 2011 2:41 pm    Post subject: Reply with quote
In addition to weight, could you please make available wind tunnel testing results?
thirdgenbird
PostPosted: Thu Dec 29, 2011 5:32 pm    Post subject: Reply with quote
i would consider a quality bolt in kit. subscribing for updates.
have you cross posted to rennlist? i dont recall seeing anything over there but they may be interested as well.
17in caymans, koni yellow coilovers, hypercoil springs, kla solid upper mounts, 968 sway bars, kla drop links, kla strut brace, fidanza flywheel, dansk catback, wilwood front calipers, ss brake lines, e-codes, 944 duckbill, manual rack,momo steering wheel
924-76
PostPosted: Thu Dec 29, 2011 9:09 pm    Post subject: Reply with quote
Not yet, thanks for the idea
1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP
Martijnus
PostPosted: Thu Dec 29, 2011 11:22 pm    Post subject: Reply with quote
you'd have to test this with the lights on and off because the light could provide an exerting force on the emitter (not sure if relativity theory still holds) hence it could create resistance. You can't measure that in a wind tunnel though... but the engine has to provide the electricity and when the light is emitted it again consumes horsepower.
Deflecting it to the skies could add some downforce on the front.
what?
I still have some hella lights btw, but I think they're too big. They do have a nice frame in which the glass is suspended, so it is fancily adjustable.
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
924-76
PostPosted: Thu Dec 29, 2011 11:38 pm    Post subject: Reply with quote
I’m afraid that this is way out of my knowledge and skill level.
But I would be more than happy to put you both first on the list (when I’m ready for production) in exchange of this crucial information.
1980 931S
PostPosted: Fri Dec 30, 2011 12:23 am    Post subject: Reply with quote
That will probably be negated because of the behaviour of the photons hitting the rotating fan assembly as the photon beams would create a non linear pressure difference in front of the car, heating the gas and therefore making it less dense...so less downforce on the fronts.
i guess you'll just have to find a different way to check if they are safe to fit on the 924
WEASEL149
PostPosted: Fri Dec 30, 2011 2:11 am    Post subject: Reply with quote
i hope this helps:
you need to address these quality issues, probably on the mold....
your part is too small...you need to make it bigger.
check out how the deutschnine products look.
Just to add to what Morghen has said, I think the most important thing to get right on these lights is the size and shape of the plexiglass covers.
To get the kit looking 'OEM' it's vitally important to maintain a consistent panel gap that falls in line with the bonnet/hood and also to achieve the black outline beneath the plexiglass.
I think this is why Deutsch Nine's kit looks so good on that blue car.
1979 UK 932
924-76
PostPosted: Fri Dec 30, 2011 4:39 am    Post subject: Reply with quote
WEASEL149 wrote:
i hope this helps:
I still have to work on it but its getting better
Thank you all for the interest and comments
1980 931S
PostPosted: Fri Dec 30, 2011 7:46 am    Post subject: Reply with quote
wow, it already looks much better ! at this point i'd almost make an order
now...one more thing:
take a look at the curvature of the metal part in the marked area.
i see that the cover has a curvature, and from this picture i cant see very well...but it looks like you could make it a bit more curved.
Also...you might try to bring the outer edge of the cover a tad closer to the marked edge of the metal part.
924-76
PostPosted: Fri Dec 30, 2011 7:55 am    Post subject: Reply with quote
Thanks again morghen, I will try to make the correction during the week-end.
1980 931S
Ian89C4
PostPosted: Fri Dec 30, 2011 10:16 am    Post subject: Reply with quote
Looking good! Thanks for the pics and the updates.
Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala")
PostPosted: Fri Dec 30, 2011 10:39 am    Post subject: Reply with quote
yea +1 on the craftmanship ... i like them.
PostPosted: Fri Dec 30, 2011 8:39 pm    Post subject: Reply with quote
Here's your marker http://images.pistonheads.com/nimg/24855/GTSLarge.jpg too big to post
Derek Bells recently refurbished at Porsche Stuttgart GTS. New headlight covers and HIDS
http://www.pistonheads.com/doc.asp?c=161&i=24823
I'd be interested in the covers, buckets and fitting kit. The headlamp units will need to be sourced in the UK due to us driving on the left unless they are not handed.
924-76
PostPosted: Fri Dec 30, 2011 9:48 pm    Post subject: Reply with quote
Wow! Thanks for the pics and link, this is very helpful.
Hum, I don’t know
How can you tell?
1980 931S
PostPosted: Fri Dec 30, 2011 10:44 pm    Post subject: Reply with quote
OT: note how he always drives it with the windows closed...he must get the fumes too
Page 2 of 16
