AGD931
Joined: 17 Mar 2003 Posts: 289 Location: Athens, Greece
Posted: Thu Nov 10, 2011 6:05 am Post subject: Fuse Panel |
Just noticed tonight that the small black fuse panel above the main fuse carrier, is sort of warm to the touch in the vicinity of fuses 1 &2 (on this smaller fuse block) fuse 2 on this is for the fuel pump relay according to the owners manual. I touched the bundle of wires leading to this fuse block to see if they had the same temperature, but they felt normal.
Is this something normal ? I am thinking that maybe the fuel pump relay could have something to do with it as a couple of times I have wiggled the relay with the engine running, it has stalled the engine on occasion.
Thanks for the help,
Arthur _________________ 1981 931 S2
1990 E30 320i Cabrio
1979 Ford Capri Ghia |
Mr Bitey
Joined: 23 Sep 2011 Posts: 54 Location: Perth, Western Australia
Posted: Thu Nov 10, 2011 4:11 pm Post subject: |
If your fuel pump is starting to wear out it will draw more Amps.
So the extra current flowing through those wires will generate more heat. _________________ Tom
___________
1979 924 NA
1979 924 NA - Parts car |
AGD931
Posted: Thu Nov 10, 2011 5:43 pm Post subject: |
Thanks for your reply Tom,
I can see your logic, but I want to think that it isn't the fuel pump was changed two years ago...!!!.
I picked up a new fuel pump relay at work today, will give it a try to see if it makes any difference, as the one I removed from the car looks a bit manky and there is something rattling inside....
Thanks
AGD931
Posted: Fri Nov 11, 2011 6:11 pm Post subject: |
Small update, fitted a new fuel pump relay, it doesnt cut out anymore if I wiggle the relay
As to the fuse panel, cant decide if there is any difference.... _________________ 1981 931 S2
