Aluminum clutch pressure plate?
engineer.white
PostPosted: Sat Sep 17, 2011 10:30 pm    Post subject: Aluminum clutch pressure plate? Reply with quote
Are there light weight pressure plates from the 911 that will fit and function in the 931? I think its from a 911 year 1972-1986..... whats the porsche part number of the Sachs part number.
1981 924 turbo/931
1982 924 turbo/931
1986 911 turbo/930
gegge
PostPosted: Sun Sep 18, 2011 5:23 am    Post subject: Reply with quote
Yes there are. Search and you find it.
Carl Fredrik Torkildsen
PostPosted: Sun Sep 18, 2011 12:06 pm    Post subject: Reply with quote
From this thread: http://www.924board.org/viewtopic.php?p=313414#313414
On a bone stock S1 931, you need (spring-damped) clutch plate 931.116.011.04 and pressure plate 931.116.001.02
If you replace the S1 flywheel with a US-spec S2 flywheel, you can upgrade to the 911 pressure plate 915.116.001.27, which provides ~2x the clamping force of the 931 pressure plate. There is another version of the 911 pressure plate that has an alu housing to reduce weight...it is part number 915.116.001.16, but they are NLA from Porsche. I got lucky and found a NOS unit 3 years ago that I'm currently planning to put into the UWB project.
I'm not sure if you can use the 915.* pressure plate on the S1 flywheel. My 941 was originally a S1 car, but the motor that's in it is mostly S2 stuff so it has the S2 flywheel. I'm not planning to use any of the S1 flywheels I have because they're heavier than the S2 flywheels.
SPEC has some nice-looking clutch packages but they're not cheap. If you want to investigate their stuff as an alternative, you would need whatever setup they say is compatible with the M31.01/02 engine, which is presumably what you have. Best to check the engine code stamped onto the block to verify for certain.
In another related thread: (http://www.924board.org/viewtopic.php?t=34417)
Here are two other alternatives, designed for the 911, but the pressure plates will work for the 931. The clutch disc will not work because it has 20T spline instead of the 931's 25T spline. I have not found a source for only the pressure plate from these kits...but haven't had time to call anybody either...
http://cgi.ebay.com/ebaymotors/SACHS-RACING-POWER-CLUTCH-KIT-Porsche-911-911S-911T-72-/330552851454?pt=Motors_Car_Truck_Parts_Accessories&hash=item4cf67c3bfe#ht_2155wt_725
http://www.ebsracing.com/item.wws?sku=901116001LWK-1&mfr=KEP
PostPosted: Sun Sep 18, 2011 12:22 pm    Post subject: Reply with quote
I think the Sachs number for the *.16 version is 3082 087 031, but still trying to confirm.
LUK also shows their part number 123 0085 20 as being a replacement for the 915.116.001.* parts, but I doubt it has the aluminum housing because it's listed for both the *.27 (iron) and *.16 versions.
Vic
PostPosted: Mon Sep 19, 2011 5:02 pm    Post subject: Reply with quote
I like politeness myself when asking assistance
gegge
PostPosted: Mon Sep 19, 2011 6:39 pm    Post subject: Reply with quote
Are you suggesting that I was unpolite? Well, I am sorry but engineer. white asked if there are aluminum pressure plates and I answered yes and by using the searchfunction it is relative easy to find the threads.
Didnīt mean to offend anyone.
Vic
PostPosted: Mon Sep 19, 2011 7:19 pm    Post subject: Reply with quote
No mate it wasn't meant for you , sorry, it was meant for the person asking the question ! No introduction, hello or hi or thankyou, just a blunt question , as i said a bit of politeness goes a long way you were great in answering the question , i have to deal with public all the time and its a personal thing to me as some people dont give a toss just demand answers OK
