Nissebus
Joined: 07 Jun 2011 Posts: 20 Location: Gothenburg, Sweden
Posted: Tue Aug 16, 2011 8:59 am Post subject: |
I haven't checked it yet. The battery discharged during the night (yep, that's another problem:P) so i put it on recharge and focused on replacing the brakes. Front and back.
I'll tell you if it worked when I put the battery back.  _________________ 924 -81 "The Frogmobile"
”Before you criticize someone, try walking a mile in their shoes. That way, when you do criticize them, you’re a mile away AND YOU HAVE THEIR SHOES!” |
PeterW
Posted: Wed Aug 17, 2011 3:06 pm Post subject: |
Yes, the high and low beam are on separate circuits - even through the fuse box.
Check continuity between the bottom half of fuse 1 and pin A19. Then check continuity between the bottom half of fuse 3 and pin A18. If you have one but not the other, you could have a fault that I ran into with a fuse box. The innards of the fuse box are zinc plated steel, and the interconnect pins are a crimped type that corrode. The pictures below show a fuse box that is badly damaged, and you can see one of the pins that has corroded open.
 _________________ 1980 931 |
AGD931
Joined: 17 Mar 2003 Posts: 289 Location: Athens, Greece
Posted: Wed Aug 24, 2011 4:01 pm Post subject: |
I still have not solved this problem, (the left low beam having a dim yellow glow & the high beam in the round headlight not coming on) having checked everything I think the problem is wit the indicator switch as the following occur -
low beam on - I switch the main beam on, main beam comes on (not the left main beam). I repeat the above & main beam does not come on at all! This can happen randomly or all the time.
All lights off & pods down - I flash the main beam, LED comes on, the bumper driving lamps flash correctly. I repeat this, the LED comes on but the bumper driving lights do not flash. This happens randomly.
Apart from cleaning everything, I have replaced the headlight relay, cleaned the headlight switch (was clean anyway).
All other indicator switch functions work properly.
Any ideas & how do I clean the indicator switch, do I have to take the steering wheel off?
Thanks for the help[/list] _________________ 1981 931 S2
1990 E30 320i Cabrio
1979 Ford Capri Ghia |
Muz924
Joined: 21 Jul 2010 Posts: 137 Location: Melbourne Australia
Posted: Wed Aug 24, 2011 8:41 pm Post subject: |
| AGD931 wrote: | I still have not solved this problem, (the left low beam having a dim yellow glow & the high beam in the round headlight not coming on) having checked everything I think the problem is wit the indicator switch as the following occur -
Thanks for the help[/list] |
Dim hello glow is usually a bad earth (I think someone mentioned this earlier in this post).
The easiest way to check this is to run a wire from the earth connection at the LH headlight (brown wire) directly back to the battery earth.
If the headlight shines nice and bright its 100% bad earth. Then you need to follow the brown wire back to its earthing point on the body and find where its going wrong!
Hope this helps.
Cheers,
Santo _________________ 1978 924 RoW 5-Speed (Current Project)
1980 924 RoW 5-Speed (Donor Car)
1985 Alfa Romeo Alfetta GTV 2.0 (Previous Project Car) |
AGD931
Posted: Thu Aug 25, 2011 2:54 pm Post subject: |
Thanks for all the rep;ies guys, much appreciated.
In the morning I cleaned the plugs on the steering column switch & checked the fusebox and relays, without any change.
The good news is that I fixed this problem yesterday afternoon. The solution was so simple I feel silly for not seeing it!
After my afternoon siesta & whilst having coffee, I thought hang on a minute the only thing I have not checked is the bulb itself, (because they are both six months old and have been used twice)TBH I could not be bothered to dismantle everything again, so I did!
I pulled the plug off the bulb and looked at the contacts, and guess what, the spade connector for the live feed was not sitting correctly in the plug itself, I refitted the connector & reassembled everything not really confident that I had fixed anything... switched the lights on & SUCCESS.
That was it, everything works as it should.! _________________ 1981 931 S2
