Posted: Thu Aug 11, 2011 10:14 pm Post subject: How I did my plexiglass quarter and door windows |
I used:
- Plexiglass
- Safty goggles
- 4 clamps
- Rotary tool with cutting bit and sand barrow
- Heat gun
- 2 sand bag
I bought plexiglass from the local hardware store.
The one I used is about 1mm thinner than the glass; it was the closest one available.
1. Trace the window shape on the plexiglass.
2. Cut the plexiglass about ½ in larger than your mark, I used a rotary tool with a cutting bit.
3. Place the window with the concave side up on a table or working space.
4. Place the plexiglass on the window.
5. Heat the plexiglass with a heat gun, be careful to not overheat it.
6. Place sand bag on it and let sit for several minute.
7. Repeat step 4 and 5 until the plexiglass hold the right curve.
8. Use few clamp to hold the plexiglass and glass together.
9. Cut the plexiglass to the same size than the window, I used the rotary tool with a sand barrow.
Because the plexiglass is slightly thinner, I put a small foam band (I cut the adhesive side) inside to keep the plexiglass tight in the gasket/weather strip.
The weight difference between the glass and plexiglass is not that big, 13lbs for the quarter and door window all together. _________________ 1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP |
dreamgts
Posted: Thu Aug 11, 2011 10:44 pm Post subject: |
Thats some nice work. Would like to do something like that to my track car project. Did you put weight on the plexi to contour it? I think its also possible to do the front sides too.
dreamgts _________________ 2 PORSCHE 924 (CURRENT PROJECTS)
2 CLASSIC CORTINAS (FINISHED)
1 CLASSIC FIAT(FINISHED)
1 CLASSIC FIAT 132 2000CC(JUST PURCHASED)
4 SUV'S
2 SEDANS
1 OPEL PANEL VAN
WIFES SUZUKI ALTO |
Posted: Fri Aug 12, 2011 1:08 am Post subject: |
Nice write up!!! Now figure out how to make the GTS-style sliders for the door windows... _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Fri Aug 12, 2011 3:48 am Post subject: |
ideola wrote: | Now figure out how to make the GTS-style sliders for the door windows... |
Sorry Dan, not for me, plus you can’t lock that slider.
I mounted my plexiglass window on the manual rail and regulator, so I can still open the window _________________ 1976 924 N/A ROW SOLD
1980 931S
Posted: Fri Aug 12, 2011 4:06 am Post subject: |
How much weight did you save exactly ? _________________ 937 trackday car
Posted: Fri Aug 12, 2011 4:14 am Post subject: |
13 lbs with the 4 fiberglass window (2 quarter + 2 door) _________________ 1976 924 N/A ROW SOLD
1980 931S
Posted: Fri Aug 12, 2011 4:39 am Post subject: |
did you use 3mm windows ? _________________ 937 trackday car
Posted: Fri Aug 12, 2011 4:53 am Post subject: |
Yes _________________ 1976 924 N/A ROW SOLD
1980 931S
tyfighter123
Posted: Fri Aug 12, 2011 8:33 am Post subject: |
Those look awesome way to go!!! _________________ Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
Porsche 931 1980 (parts car) |
