How I did my plexiglass quarter and door windows
PostPosted: Thu Aug 11, 2011 10:14 pm    Post subject: How I did my plexiglass quarter and door windows Reply with quote
I used:
- Plexiglass
- Safty goggles
- 4 clamps
- Rotary tool with cutting bit and sand barrow
- Heat gun
- 2 sand bag
I bought plexiglass from the local hardware store.
The one I used is about 1mm thinner than the glass; it was the closest one available.
1. Trace the window shape on the plexiglass.
2. Cut the plexiglass about ½ in larger than your mark, I used a rotary tool with a cutting bit.
3. Place the window with the concave side up on a table or working space.
4. Place the plexiglass on the window.
5. Heat the plexiglass with a heat gun, be careful to not overheat it.
6. Place sand bag on it and let sit for several minute.
7. Repeat step 4 and 5 until the plexiglass hold the right curve.
8. Use few clamp to hold the plexiglass and glass together.
9. Cut the plexiglass to the same size than the window, I used the rotary tool with a sand barrow.
Because the plexiglass is slightly thinner, I put a small foam band (I cut the adhesive side) inside to keep the plexiglass tight in the gasket/weather strip.
The weight difference between the glass and plexiglass is not that big, 13lbs for the quarter and door window all together.
1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP
dreamgts
PostPosted: Thu Aug 11, 2011 10:44 pm    Post subject: Reply with quote
Thats some nice work. Would like to do something like that to my track car project. Did you put weight on the plexi to contour it? I think its also possible to do the front sides too.
dreamgts
2 PORSCHE 924 (CURRENT PROJECTS)
2 CLASSIC CORTINAS (FINISHED)
1 CLASSIC FIAT(FINISHED)
1 CLASSIC FIAT 132 2000CC(JUST PURCHASED)
4 SUV'S
2 SEDANS
1 OPEL PANEL VAN
WIFES SUZUKI ALTO
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
PostPosted: Fri Aug 12, 2011 1:08 am    Post subject: Reply with quote
Nice write up!!! Now figure out how to make the GTS-style sliders for the door windows...
924-76
PostPosted: Fri Aug 12, 2011 3:48 am    Post subject: Reply with quote
Sorry Dan, not for me, plus you can’t lock that slider.
I mounted my plexiglass window on the manual rail and regulator, so I can still open the window
1980 931S
PostPosted: Fri Aug 12, 2011 4:06 am    Post subject: Reply with quote
How much weight did you save exactly ?
924-76
PostPosted: Fri Aug 12, 2011 4:14 am    Post subject: Reply with quote
13 lbs with the 4 fiberglass window (2 quarter + 2 door)
1980 931S
PostPosted: Fri Aug 12, 2011 4:39 am    Post subject: Reply with quote
did you use 3mm windows ?
924-76
PostPosted: Fri Aug 12, 2011 4:53 am    Post subject: Reply with quote
Yes
1980 931S
tyfighter123
PostPosted: Fri Aug 12, 2011 8:33 am    Post subject: Reply with quote
Those look awesome way to go!!!
Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
Porsche 931 1980 (parts car)
