joejax
Joined: 02 Dec 2009 Posts: 919 Location: Jacksonville,FLA,USA
Posted: Sun Jul 17, 2011 10:33 am Post subject: Uh Oh! Timing belt failure, now what? |
Cruising along today at about 65 mph, suddenly a pop and engine quits. No other noise, just quit.
Coasted off the road, thought I was out of gas, pop the hood to find the belt shredded. Called buddy to tow home about 10 miles (fun).
Been running great lately, hope nothing else is broken. Should I be worried? Have belt and pulley, just haven't got around to change them, yet...  _________________ I got nothin'
Uhhh...you got any pics? |
Posted: Sun Jul 17, 2011 12:01 pm Post subject: |
This is on your 924 n/a?
No worries. It's not an interference engine like the turbo. _________________ [This Space For Rent] |
Posted: Sun Jul 17, 2011 9:08 pm Post subject: Re: Uh Oh! Timing belt failure, now what? |
| joejax wrote: | Have belt and pulley, just haven't got around to change them, yet...  |
Guess you will, now!  _________________ Vaughan Scott
Martijnus
Posted: Mon Jul 18, 2011 12:07 am Post subject: |
I once ripped all teeth off at the highway..
no problem. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
the_mad_electrician
Joined: 16 Nov 2009 Posts: 1073 Location: Central Georgia
Posted: Mon Jul 18, 2011 1:54 am Post subject: |
| Martijnus wrote: | I once ripped all teeth off at the highway..
no problem. |
The samething happened to be! I was driving about 75 MPH actually made it almost 3 miles _________________ 81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6 |
Posted: Mon Jul 18, 2011 3:24 am Post subject: |
Running with cam timing off can fubar your injectors. _________________ Toofah King Bad
joejax
Posted: Mon Jul 18, 2011 5:21 am Post subject: |
Hee hee , Got lucky I guess, stalled on break, able to coast off busy 2 lane onto another road.
Had new belt in car but no tools. Changed today, not too bad of a job, I can see why so many leave that blasted cover off though.
I thought I read on here about a NA motor got damaged by belt failure, so I was worried. I may have been mistaken. _________________ I got nothin'
Posted: Mon Jul 18, 2011 8:04 am Post subject: |
Only if you're running really high compression would a broken belt be an issue. _________________ Stefan
Martijnus
Posted: Fri Jul 22, 2011 6:23 am Post subject: |
| Rasta Monsta wrote: | | Running with cam timing off can fubar your injectors. |
Mine didn't run ofcourse since it had as much teeth as your average meth addict. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
Min
Posted: Fri Jul 22, 2011 10:48 am Post subject: |
| fiat22turbo wrote: | | Only if you're running really high compression would a broken belt be an issue. |
Or if the broken belt is a symptom of a different issue.
joejax
Posted: Fri Jul 22, 2011 12:33 pm Post subject: |
| Min wrote: | | fiat22turbo wrote: | | Only if you're running really high compression would a broken belt be an issue. |
Min |
What could be a different issue?  _________________ I got nothin'
the_mad_electrician
Posted: Fri Jul 22, 2011 12:52 pm Post subject: |
Cam seized up maybe? If something like that happened I think you'd know about it _________________ 81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6 |
Posted: Fri Jul 22, 2011 1:36 pm Post subject: |
Broken valve springs is another issue that could cause a valve and piston meeting.
Broken connecting rod, etc.
Both of these issues would be pretty obvious  _________________ Stefan
Min
Posted: Fri Jul 22, 2011 3:17 pm Post subject: |
In my case, seized a lifter, broke the cam belt, also broke the cam gear (cracked the hub) etc.
joejax
Posted: Sun Jul 24, 2011 10:03 am Post subject: |
Ya'll got me more nervous than a long tailed dog in a room full of rockin' chairs!
Got to take it for a ride today, running OK, may need to adjust the timing a bit though..
Hotter than sacks of ball here, black on black is killin' me, no AC either, really need to get that fixed.  _________________ I got nothin'
