Pilot bearings.
Goto page 1, 2, 3, 4  Next
PostPosted: Mon Mar 14, 2011 7:47 am    Post subject: Pilot bearings. Reply with quote
Question am I correct that pilot bearings are different sizes from a early NA non-turbo and a early turbo, with the turbo being a bigger unit
as the splined input shaft from the torque is bigger.
ic932
PostPosted: Mon Mar 14, 2011 9:35 am    Post subject: Reply with quote
Correct sir...the 931 has a simple traditional style bearing, pressed into the flywheel (IIRC..not the crank ala 944...although the bearing is identical) I PRESUME the inner bearing diameter would be larger on the 25mm shaft compared with the 20mm? Either way, you need the 931 specific spigot (pilot) bearing. I've rea about the funky 924 bearing but not witnessed it ...thank the lord.
BANNED
PostPosted: Mon Mar 14, 2011 1:41 pm    Post subject: Reply with quote
Yes, that would be they have different part numbers and different listed, when you look them up.
PostPosted: Tue Mar 15, 2011 1:17 am    Post subject: Reply with quote
Look whaa?
ic932
PostPosted: Tue Mar 15, 2011 2:52 am    Post subject: Reply with quote
Very good point. Trouble is part numbers change but specs can remain the same. PET is full of...
BANNED
PostPosted: Tue Mar 15, 2011 3:02 am    Post subject: Reply with quote
Will a na bearing fit into the 931 crank along with na
sachs clutch/flywheel.
ic932
PostPosted: Tue Mar 15, 2011 4:00 am    Post subject: Reply with quote
Just skip your weekly bikini wax expeniture and buy the bearing instead mate.
BANNED
PostPosted: Tue Mar 15, 2011 4:37 am    Post subject: Reply with quote
Cranks are identical so yes you could probably figure out a way to rig up the NA clutch assembly & bell housing. Obviously, the flywheel would need to be marked for the Turbo timing marks, and you'll be more susceptible to clutch slippage, but I can't think of anything at the moment that would prevent bolting on the NA clutch arrangement to a turbo motor.
PostPosted: Tue Mar 15, 2011 5:01 am    Post subject: Reply with quote
Sanity perhaps?
ic932
PostPosted: Tue Mar 15, 2011 5:02 am    Post subject: Reply with quote
Frankly thats just bad advise. I'm fresh from doing an axle stand in the rain clutch job..some man stateside sell the guy a turbo flywheel for christ sakes...
BANNED
PostPosted: Tue Mar 15, 2011 5:39 am    Post subject: Reply with quote
Unless you're trying to do what Joe's trying to do, which is to put a 931 lump in an NA body. It's not the path I would take, but it can be done, and to avoid having to drop the rear suspension to change out the torque tube, it might be a viable alternative to consider...especially bearing in mind that those honker torsion carrier bolts often fuse to the aluminum sleeves making it virtually impossible to get the rear carrier out (which is required if you want to change the torque tube).
PostPosted: Tue Mar 15, 2011 5:55 am    Post subject: Reply with quote
Not yet. I know I should make and eat the 2 pieces of toast 4 egg
omelet with 2 kinds of cheese,onions peppers & garlic, though not yet.
Its a new clutch so by the time the 931 lump is dialed in with
the intercooler! It will be time to swap outthe torque tube and rear
carrier. Something like that.
PostPosted: Tue Mar 15, 2011 5:56 am    Post subject: Reply with quote
Umm...yeah. OK. Something like that. Wow.
ic932
PostPosted: Tue Mar 15, 2011 6:37 am    Post subject: Reply with quote
No its not viable and not worth considering....like I said, extremley bad avise cos it don't work, given the amount of work envolved I would describe your advise as morally neglegent...its no fun working under these cars mate.
BANNED
PostPosted: Tue Mar 15, 2011 7:24 am    Post subject: Reply with quote
[ignore]ic932[/ignore]
Page 1 of 4
