What is your oil pressure, cranking cyl pres and oil u use ?
Kongle
PostPosted: Sat Mar 05, 2011 8:14 am    Post subject: What is your oil pressure, cranking cyl pres and oil u use ? Reply with quote
I am using 10w40 and I get 7bar oil pressure = about 100psi on startup and it drops to 5bar normal driving .. is this normal ?? I think the pressure drops if I use a thicker oil like 15w-40 or 20w50 .. what is your guy's thoughts on that ??? I am going to measure my cylinder pressure soon ... cool if you guys want to share your own data to compare
Kongle
PostPosted: Sun Mar 06, 2011 3:18 pm    Post subject: Reply with quote
I got up to 9bar pressure just after start up ...
