Posted: Tue Jun 29, 2010 2:00 pm Post subject: |
Yes it is possible, and factory parts are still available, cheep:
477 501 095 - Mounts (2)
133 411 333 - Retaining bows (2) _________________ Toofah King Bad
isuras2
Posted: Tue Jun 29, 2010 9:18 pm Post subject: |
I know the parts are available. I was more interested in if there would be interference that would make welding difficult. _________________ Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew |
gerben1986
Joined: 13 Mar 2008 Posts: 232 Location: The Netherlands
Posted: Mon Jan 10, 2011 12:43 am Post subject: |
I'm also thinking about this conversion, but how many work is it to remove and reinstall the eccentric bolt on the arms?
Because I believe that bolt is for adjusting the wheel. Do you need to readjust it after installing the sway bar? |
gerben1986
Posted: Fri Mar 04, 2011 7:35 am Post subject: |
I've done this job last saturday.
We had a carbridge, and then it can be done very quickly.
But we spend a lot of time measuring, lunching, and so on.
The most difficult part was to remove the old centric bolt and to get the U-turns around the torsion tube. |
Posted: Fri Mar 04, 2011 8:27 am Post subject: |
isuras2 wrote: | I was more interested in if there would be interference that would make welding difficult. |
No. _________________ Toofah King Bad
Posted: Wed Mar 21, 2012 3:33 pm Post subject: |
pocketscience wrote: | leadfoot wrote: | Whiteline sell brackets to mount the rear swaybar - KU3 universal fits the best |
CORRECTION: Does not f*cking fit.
Grrrr, sh1t, bugger, f*ck. |
saw this...
??? think all it took was to groove the torsion carrier a couple of mils top + bottom with a round file and I got the loops to snug up to the carrier tube....
the whiteline kits has very chunky straight bars that run across the torsion bar too, think I may have flat filed the torsion bar in that area also again to make sure it stayed put, this was all in situ stuff as I didn't pull the carrier off...
maybe the 95 diameter would have suited better then??
Gav what issues did you have???
chris79
Posted: Tue Mar 17, 2015 7:04 pm Post subject: |
I vould like buy sway bar of turbo 924 and install on my '79 924 na, that has not sway bar front and rear.
It's possibile without any problem ? |
Posted: Tue Mar 17, 2015 7:32 pm Post subject: |
If your car is from Europe, you have a both front and rear sway bars.
If your car is from USA it may be possible that you dont have the rear one, but the front sway bar is 100% surely there. _________________ https://www.the924.com |
chris79
Posted: Tue Mar 17, 2015 8:05 pm Post subject: |
Are you sure ?
I have not seen, then I have to look better under the car. |
Posted: Tue Mar 17, 2015 8:14 pm Post subject: |
Unless someone took them out, you should have them.
chris79 wrote: | Are you sure ?
chris79
Posted: Tue Mar 17, 2015 8:19 pm Post subject: |
but sway bar of turbo are more rigid, this can make some improvements ?
Or I have to change even shock absorbers ? |
kcoyle
Joined: 15 Jan 2011 Posts: 712 Location: Long Island, NY
chris79
Posted: Wed Mar 18, 2015 1:06 am Post subject: |
Have you some photos of sway bar installed at front and rear ? |
Posted: Wed Mar 18, 2015 1:51 am Post subject: |
chris79 wrote: | Have you some photos of sway bar installed at front and rear ? |
chris79
Posted: Wed Mar 18, 2015 7:11 am Post subject: |
ahahahahah
I have no sway bar front and rear:
FRONT
REAR
there are not other bars. |
