gla924sem
Joined: 08 Nov 2002 Posts: 405 Location: Taylor, Michigan
Posted: Wed Feb 09, 2011 10:59 pm Post subject: Show Us your AccuSump Installation |
As part of my engine rebuild project......am installing a 3 qt AccuSump.
Man.......that thing is huge!!!!!!!!!!!!
Anyone that's installed one.....please post some pics........... |
Posted: Thu Feb 10, 2011 12:42 am Post subject: |
I don't think I have any pics, but... mine is slanted across the passenger side floor. I have a manual valve model, so must be able to reach the valve while seated; this puts the valve next to the tunnel, able to be reached unless I'm strapped down completely, and the other end with gauge is forward up by the base of the a-pillar.
Previously we had it mounted longitudinally where the passenger's seat was, but of course that was a problem for DE's - hence we relocated it. In the current location, the seat just clears it. _________________ Vaughan Scott
Posted: Thu Feb 10, 2011 12:47 am Post subject: |
No pix of mine either, but I'm installing it in the rear, down in the spare tire well. _________________ erstwhile owner of just about every 924 variant ever made |
gla924sem
Posted: Thu Feb 10, 2011 1:58 am Post subject: AccuSump |
That's what I was figuring for installation.
Mine came with a quick disconnect to the sump so I can remove it for DE if I desire. |
Posted: Thu Feb 10, 2011 3:36 am Post subject: |
I've mounted about 6 Accusumps and always try to get them as close to the engine as possible. Mostly like what Vaughan describes. There is a significant pressure drop with a longer feed line to the rear of the car and the reaction time is increased both in filling and discharging. The oil in the fully charged Accusump is ambiant temperature and is slow moving when cold even in -12 line. When the oil pump cavitates, the one way valve closes and the Accusump air bag tries to push the cold oil towards the bearings.
The way to tell if an Accusump is worth it is to feel it after hard driving. If the body of the Accusump is warm/hot, it has been swapping oil with the engine and pump.
I've always used manually operated valves that were reachable by the driver and it's something the crew chief always reminds the driver both in and out of the pits; Accusump off/Accusump on. One of my teammates had an electrically operated one on the ex-Grand Am car and it failed. We went back to the manual version.
Chuck _________________ 1979 924 NA race car H-Prod SCCA
1981 924 Turbo sold
1982 924 Turbo sold
Posted: Thu Feb 10, 2011 4:09 am Post subject: |
| Fifty50Plus wrote: | | The way to tell if an Accusump is worth it is to feel it after hard driving. If the body of the Accusump is warm/hot, it has been swapping oil with the engine and pump. |
Interesting! Mine is usually very warm after a session; not as hot as the engine, but definitely uncomfortably warm!! Will have to measure that sometime with the ol' pyrometer!
But that explains the temp a lot more than just ambient heat from the floor/exhaust.
Re: air "bag" - mine has an o-ringed piston, not a "bag" - really a disc - to seal between the air and the oil halves of the chamber... _________________ Vaughan Scott
Posted: Thu Feb 10, 2011 4:33 am Post subject: |
@Chuck
Have you always installed them in the cabin of the vehicle vs. somewhere in the engine bay? I think I can make room to put mine up front somewhere, but I've heard concerns over the cylinder getting damaged and impeding piston travel... _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Thu Feb 10, 2011 8:04 am Post subject: |
Vaughan is correct, it's a piston type arrangement that you pre-charge with about 10 lbs of air pressure when you install it empty.
Dan - I've always put mine next to the shifter so that I can reach the on/off valve and see the pressure guage. If I were to install one in the engine compartment I would need to cobble up a manual remote lever arm thingie. Now that I think about it, location up front might be too tight. I use about a yard of -12 from the accusump back to the one way valve and bearing side of the engine.
Before I started installing these on our BMW 2002s back in the early '90s we lost 3-4 motors with rod bearing failure. After plumbing in the Accusumps we never had another failure. But the Accusumps always got warm/hot. The one I have in the enduro Benz right now rarely gets warm.
From the factory, the Benz has an amazing oil pan baffling system.
Vaughan - have you always had the crank scraper with the Accusump?
1981 924 Turbo sold
1982 924 Turbo sold
Posted: Thu Feb 10, 2011 9:22 am Post subject: |
My challenge is that I can't put it in the cockpit because I'm setting the car up for two seats. I could put it in the back seat area (I've already done the rear seat delete, but it seems like it would be safer to have it in the rear of the vehicle out of the seating area. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Thu Feb 10, 2011 10:51 pm Post subject: |
Yes, I've always had both accusump and crank scraper, or nothing (back when I blew a bunch of motors).
As for Dan, your situation - you can have the valve separate of the sump body. So you could install the sump way in the back, out of the way, and have the oil hose pass up through the cockpit to where you can get to it.
Wouldn't affect what Chuck's pointing out about response time, but would address packaging. _________________ Vaughan Scott
Posted: Thu Feb 10, 2011 11:32 pm Post subject: |
Well, another alternative would be to put it on the "hump" at the rear of the torque tube tunnel in the cockpit.
Hmm. I'll have to think about this some more. I'm getting the chassis back from my body man this Saturday, so I'll have opportunity to look at alternatives. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Thu Feb 10, 2011 11:46 pm Post subject: |
Dan,
If you move the battery to the rear, can you weasel it up in the old battery area? And for your case, an electrically controlled on/off valve might be the ticket for a clean cockpit passenger seat area.
1981 924 Turbo sold
1982 924 Turbo sold
gla924sem
Posted: Thu Feb 10, 2011 11:46 pm Post subject: AccuSump |
With my engine out......I've looked at the engine bay.......there's no way I can see installing that thing in there.
I thought about on the right side fender well since the WS washer tank is gone.......even there..... no room for that 3 qt monster.
Will be installing it in the passenger side footwell......somewhere??????
Not excited about having 3 qts of oil in the passenger compartment but there's really no where else for it to go.
In the spare tire well.......that's a lot of braided hose to run
From my research......the valve need to be driver accessable. |
Posted: Thu Feb 10, 2011 11:55 pm Post subject: |
The setup I purchased had been installed on a 951 in the spare tire well, and came with the electric valve and enough braided hose to make the run from front to back so I have what I need (short a bulkhead connector) to install it in the rear.
But the time lag issue that Chuck raised has me rethinking the location. I'm not crazy about having 3 qts of oil in the cockpit either, and I need the passenger side to be functional. I could eliminate maybe 3-4 feet of hose by putting it somewhere in the rear seat area (rear seat is deleted already). I'll have a look at the batter tray area. Might be a way to make that work. The other possibility is somewhere in the nose section, but I'm concerned about damage to the cylinder up there. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Fri Feb 11, 2011 12:58 am Post subject: |
While having the sump in the passenger compartment can certainly be a PITA for legroom etc... it's pretty safe. I'll remind everyone that I got t-boned REAL HARD by a Swedish Tank, aka Volvo 140... right where the sump was mounted... and it was fine, stayed in the car. _________________ Vaughan Scott
