Euro924S2
Posted: Wed Sep 29, 2010 11:21 pm Post subject: Clutch power handling capabilities? |
Hi guys, I'm looking into clutch options for my supercharger project (240bhp target) - I need to decide on a clutch so I can then decide on a gearbox plan - keep my audi 5 speed (remember i'm in UK) 20mm input from the NA, swap in all the donor parts from the 931 snailshell (which most likely will need a rebuild) or swap in a 944/951 box and TT - so my question is ....
1) What BHP and torque have people been able to run with an 2.0L NA standard clutch?
2) What BHP and torque will a 931 standard clutch handle?
3) What BHP and torque will a Bronco II clutch handle??
4) Any experience from using 'Staged' clutches on a fast road car? (OK or a PITA in traffic??)
Cheers, John. _________________ UK spec '83 N/A with 931 motor with Eaton MP62 'charger @ 15psi. EFI - 565cc inj. Standalone Adaptronic ECU. 951 FMIC. Ally rad. Twin throttle. Recirc valve. Custom manifolds and CAI. 232bhp |
Posted: Fri Oct 01, 2010 5:27 am Post subject: |
From my personal experience:
-931 clutch holds 200-230 HP no problem.
-944 gearbox will hold for sprinted driving on the streets (200-230HP)
I think that if you want over 200HP you have to swap the 944 torque tube and gearbox. _________________ https://www.the924.com |
Posted: Fri Oct 01, 2010 6:05 am Post subject: |
I was thinking about getting into a uprated spec clutch for a bronco II for my build.. _________________ [This Space For Rent] |
endwrench
Posted: Thu Oct 07, 2010 1:18 pm Post subject: |
You might take a look at this thread:
http://www.924board.org/viewtopic.php?t=22052
It has some power handling numbers and considerations on a supercharged NA motor. I also converted to a 944 trans and tube at the same time.
Posted: Thu Oct 07, 2010 8:47 pm Post subject: |
I just purchased a spec stage 2+ according to the manufacturers they told me it will meet my hp and torque requirements 200 to 230 hp on a 924 was $445 including pilot and throwout bearing and alignment tool it's in the post atm _________________ 1979 NA
my Porsches Arse!!! |
