What makes a club sport a club sport?
Goto page Previous  1, 2, 3 ... 6, 7, 8 ... 22, 23, 24  Next
PostPosted: Fri Sep 03, 2010 9:14 am    Post subject: Reply with quote
Fitting the crank scraper:
bnoon
PostPosted: Fri Sep 03, 2010 11:03 pm    Post subject: Reply with quote
Looks very nice Dan!!! I'm guessing the scraper needs clearancing depening on rod choice, bolt choice, etc. Almost seems a shame to have to cover it up, it's so purdy!!!
'80 924 Turbo - SOLD!
1986 Porsche 944 Turbo - SOLD!
Porscheless
PostPosted: Fri Sep 03, 2010 11:12 pm    Post subject: Reply with quote
This scraper was made specifically for my stroker setup with the Crower rods. But regardless, the scraper is close, but not "precision" close. I had to grind material off of the scraper where each of the rod ends are at maximum horizontal distance from the crank centerline. I also had to clearance one of the holes in the wire mesh for the bolt to fit through. And, I ran out of time to work on fitting the oil pan. There is something on the front end of the assembly that is preventing the pan from seating properly. I think it's some of the heat sink fins on the inside of the pan, but that should be easy to address.
bnoon
PostPosted: Fri Sep 03, 2010 11:56 pm    Post subject: Reply with quote
Yeah that shouldn't be to tough to handle. Good luck! I can't wait until you get this engine broken in so that we can hear how much power it's putting down.
Are you going to add an intercooler? I'd like to see a 2.0 stroker really get pushed...
Porscheless
PostPosted: Sun Sep 05, 2010 1:20 am    Post subject: Reply with quote
My goal with the club sport project is to put together a 931 that is "close" to Euro specifications. The only reason I went with the stroker is because I had an extra complete setup on the shelf, so it was cheaper for me to build it than to start from scratch with a stock motor. I expect the car should put out somewhere around 180 BHP, give or take. Since the CR is a bit lower than Euro spec, I expect the stroker to be a rough tradeoff to achieve near-Euro spec power levels.
I have toyed around with the idea of upping the boost and adding an intercooler, but if I do, it will be done at a later date and not part of the initial build. I am still hoping to get this car completely built, broken in, and possibly some basic tuning before I have to put it away for the winter. If I can do that, then my focus over the winter will shift to body work on this car, and building a new motor for the 941, which has a problem on the #2 intake valve that requires the motor to come out. If I can get both of those things done over the winter, then I'll be able to bring the UWB project back to the front burner next spring. The UWB will have an identical long block setup to the CS (stroker, big valve head, Integral Stage 1), but will be the all-out build, with custom turbo, intercooler, boost control, EFI, etc.
PostPosted: Sun Sep 05, 2010 2:57 am    Post subject: Reply with quote
FWIW, mine (scraper only, no windage) had to be ground in a few places as well.
PostPosted: Thu Sep 23, 2010 6:19 am    Post subject: Reply with quote
Engine bay, getting ready for the powerplant:
968 running gear and test fitting of 7Jx16 club sports:
tyfighter123
PostPosted: Thu Sep 23, 2010 3:08 pm    Post subject: Reply with quote
Looking good!
Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
Porsche 931 1980 (parts car)
tyfighter123
Looking good!
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
PostPosted: Thu Sep 23, 2010 11:23 pm    Post subject: Reply with quote
Looking good!
PostPosted: Fri Sep 24, 2010 1:01 am    Post subject: Reply with quote
Looking good!
9xx
PostPosted: Fri Sep 24, 2010 2:10 am    Post subject: Reply with quote
Looking good!
Mikko
All gone: 931 '82 Alpine White, original option "220" G31 with LSD + 3 x 944
PostPosted: Sun Oct 17, 2010 9:57 am    Post subject: Reply with quote
Almost ready.
Next up: all the hoses.
JayZzzz4
PostPosted: Sun Oct 17, 2010 10:34 am    Post subject: Reply with quote
Looking Good!
White 1987 Porsche 924S manual
PostPosted: Sun Oct 17, 2010 7:15 pm    Post subject: Reply with quote
Wow! Luverly bit of bling there. Will be a shame to get it oiled up and dirty.
Page 7 of 24
