Let's play before and after
emoore924
PostPosted: Sat Aug 21, 2010 1:02 pm    Post subject: Let's play before and after Reply with quote
Before
After
I kinda like the after better myself. And yes, it is as good on the inside as it looks on the outside. Haven't started tuning things yet but she howls like a pack of banshees released from the gates of hades.
PostPosted: Sat Aug 21, 2010 1:06 pm    Post subject: Reply with quote
<= has chubby
PostPosted: Sat Aug 21, 2010 1:15 pm    Post subject: Reply with quote
Very tidy! Is that the big valve head, or was that for a different project? How 'bout some specs?
Zeek
PostPosted: Sat Aug 21, 2010 1:16 pm    Post subject: Reply with quote
Did you change out one of the pulleys as well?
That is a VERRRRY clean engine. Congrats on a job well done.
emoore924
PostPosted: Sat Aug 21, 2010 1:29 pm    Post subject: Reply with quote
Hmm, specs. I don't want to tell all. But here are a few tidbits.
Yes, it has one of the big valve heads I got my hands on, full P&P, manny matched, all that, etc.
Cossie alloy pistons, custom cut to work with the big valve head.
Elgin race cam
10.5:1 CR
45 DCOE
Fidanza Al flywheel
Same bursch jet-hot header as before, straight pipe to the supertrapp. L-O-U-D, 'specially when she comes on cam. I think this might change a little as I get the timing dialed in.
The tensioner has been moved of course to accommodate the change in head-block geometry. I think I'll go with an adjustable cam pulley but haven't found one I like yet.
Bottom end has had some work done, mostly for longevity, but has been balanced, lightened, etc., enough so to make things interesting.
There's also some really trick stuff there that's not obvious too that the builder did, like that's an S2 throttle cable on the webers that's wrapped back around on itself with the pulley vertically at the back of the carbies. And, he replaced the coolant tank with a 944 unit to clear out the front of the engine compartment. I just stood there looking at it and there's little cool things all over the place where its been tweeked and changed that you just don't notice right away.
So anyway, I still have a bunch of stuff to do, and have to get through the break-in period but wow, it really has shown some potential. This ain't your grandma's toofah.
PostPosted: Sat Aug 21, 2010 2:01 pm    Post subject: Reply with quote
Yeas Ive kind a been round the corner on this emoore924..
and I can say from the descrip and picsits just nasty.
Good work man.
PostPosted: Sat Aug 21, 2010 8:16 pm    Post subject: Reply with quote
Is that a phenolic spacer I see between the carbs and the mani?
the_mad_electrician
PostPosted: Sun Aug 22, 2010 2:03 am    Post subject: Reply with quote
Wow 10.5:1 that's some impressive compression! I'm going to steal that idea about the 944 coolant tank Where'd you get those plugs for the old injectors?
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
PostPosted: Sun Aug 22, 2010 2:29 am    Post subject: Reply with quote
Looks great. . .and you probably know this, but there are some adjustable pulleys for Rabbit Mark I that will work.
PostPosted: Sun Aug 22, 2010 11:52 am    Post subject: Reply with quote
Hook up some oxy. masks and a tank cause youll need it the way your gonna fly chuckle chuckle.
emoore924
PostPosted: Mon Aug 23, 2010 3:11 am    Post subject: Reply with quote
Yeah, 10.5:1 took us a little while but we were able to do it with a combo of pistons, head, head gasket and block "adjustments" to get it all to come together and hit the targeted CR. So far so good on pump gas.
That 944 tank is one of those "Duh, I wish I'd thought of that" kind of things. A very clean idea that un-clutters the front/top of the engine compartment and very simple too. IDK if it would work with a regular 924 raddy but I guess it would, why not? Simply a matter of fabrication.
The plugs for the old injector holes in the head are simply injector plugs with a penny (or was it a nickle) placed at the bottom of the hole, then the plug was screwed in with a little permatex. They're taking vacuum not pressure so they just have to seal.
Yep, phenolic spacers.
Thanks for the tip on the cam pulley. I will check that out.
PostPosted: Mon Aug 23, 2010 6:36 am    Post subject: Reply with quote
.... Emoore924 cheers youve really surprised me with the build..
Think youll get any clutch slippage that might be somemthing to
address bout. Watch out you dont run over any more parts or
anything else sitting in the drive behind it or we will start calling you runovermoore parts 924,
Cheers Joes924racer.
lo41 black 924
PostPosted: Mon Aug 30, 2010 1:49 am    Post subject: Reply with quote
i know about these engines they dont respond well to tuning i think you can expect to see about -5 drop in bhp with all the work esitmated 90 bhp
Nobbi
PostPosted: Mon Aug 30, 2010 4:26 am    Post subject: Reply with quote
yes, 90 horses.Thats what the Light truck Volkswagen LT delivers with the carb setup. Dont get why people doing it anyhow?
NA 924 - april/1977- 4-speed-audi gearbox.
500.000 km with fun.....and new toy:Porsche 944 S2 Cabriolet.Other car Daimler c-class cabby,brandnew!
Plus new in the stable..1982 NA in grand prix white.Plus : DEUTZ 4005 tractor Built 1969
the_mad_electrician
PostPosted: Mon Aug 30, 2010 5:05 am    Post subject: Reply with quote
Head work, 10.5-1 compression, hot cam, Webers. If he sees less power with this set something is wrong with the universe.
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
