High Beams
924mang
PostPosted: Sun Oct 06, 2002 1:56 pm    Post subject: Reply with quote
Okay, here we go... My right high beam does not work. First thought, blown bulb. So I went out, got two new bulbs(two so it would be visually pleasing ). I put the new bulb in place of the old suspected blown one. Low beam works, but high beam still does not. Wireing?
Also, I cant get the damn screws holding the other light out, they are frozen and wont budge. ANY ideas? any help would be appreciated, now if you'll excuse me, if you want to find me I'll be the one with either one halogen high beam driving down the road, or two different color headlights...
(just testing the smilies, I dont know how to use them)
PostPosted: Sun Oct 06, 2002 2:20 pm    Post subject: Reply with quote
I'd suggest that you check the voltages at the bulb carrier. If the high beam is zero it's a break if it's under 12v it's corrosion.
If it was a 924 I'd put money on the 3-way connector behind the lights being corroded. Could also be the earth point - on the chassis rail behind the lights in a 924, don't know about the S.
