johnathan1
Posted: Mon Nov 26, 2007 8:19 pm Post subject: |
Wow, I know this is an old thread...but nobody has the pictures that go with this DIY anymore? _________________ -1977 924, 4-Spd...Gone
-1987 Toyota Supra Turbo, Pearl White, BPU, 300RWHP @ 10psi.
-1989 Mercedes-Benz 300SEL
WARNING: MAY CONTAIN TRACES OF AUDI OR VW! |
colin
Posted: Tue Nov 27, 2007 1:46 am Post subject: |
i got a 79 two years ago, im almost certain the problem with it is with the fuel, it runs very rich, i once had gas in the oil, ive went through and changed many things on the car like the fuel pump, filter, and distributer, but i still have the same problem too much fuel. the exost comes out black and the spark plugs are wet when the engine dies. the car isnt able to start many times and when it is running it cant go much faster than 15 or 20 mph. any ideas? _________________ 1979 924 parting ways
1987 924S
1987 parts car |
dpw928
Posted: Tue Nov 27, 2007 2:05 am Post subject: |
Colin,
That is the same symptoms I had on my 928 euro. Turns out the internal o rings in the fuel distibutor were toast/broken/cracked. This allowed system pressure (5+ bar) rather than the normal 3 bar to go to the injectors. Vaughns writeup refers to them as 4 oval shaped o rings. I was able to find some at the local autoparts store. Make sure you get the fuel resistant type.
78 928 5 sp Silver
78 928 AT Euro Black |
El Chato
Posted: Thu Jul 09, 2009 2:55 pm Post subject: |
Cool DIY, im doit for two dizzys, now they are well clean but now seeking for orings, I found a set of vinton brown fuel orings at harbor tool for 20 bucks, one question, the orings that go around the cylinder on the lower head, are those originally round or square, I like to replace them but not take them out yet, I found that sumerging the cylinder in chemtool, or similiar name made them expand and after hours they came too a thinner size it seems.
If it works Ill put the rebuild unit in my running car and test it. _________________ 1979 924 N/A, Snail Shell
1980 924 N/A
1976 924 N/A
It may be that your whole purpose in life is simply to serve as a warning to others.
Today's weirdness is tomorrow's reason why. |
Posted: Fri Jul 23, 2010 2:53 am Post subject: |
This should be moved to the How-To section (so it doesn't get buried in General Discussions). _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Fri Jul 23, 2010 3:08 am Post subject: |
We should also add a poll to keep tabs on people's success rate. . .reputedly very low for this job. _________________ Toofah King Bad
Posted: Fri Jul 23, 2010 3:23 am Post subject: |
Rasta Monsta wrote: | We should also add a poll to keep tabs on people's success rate. . .reputedly very low for this job. |
Yeah, I've been reading the threads, and it seems like the success rate is one in three attempts before everything works. I noted in the 928 doc linked above that they actually recommend a specific sealant, Permatex Indian Head Shellac; Sealing seems to be one of the main issues reported. _________________ erstwhile owner of just about every 924 variant ever made |
Joined: 29 Jul 2001 Posts: 8794 Location: Royal Oak, MI, USA
Posted: Fri Jul 23, 2010 10:11 pm Post subject: |
Dang, yeah this is an old one!
Moved as suggested... probably posted it before we had a How-To section. _________________ Vaughan Scott
