chad-tanner
Joined: 23 Mar 2008 Posts: 217 Location: New Madrid,MO
Posted: Wed May 05, 2010 10:54 am Post subject: Fuel lines 924 VS. 931 |
I'm hoping some of you guys are familiar with who I am,or should I say,familiar with what I'm doing.I sure hope so...Because.. I'm sometimes embarrassed explaining myself!!!!
Anyways, I'm installing the fuel lines on my project car. I've cut the stock lines off somewhere,about even with,and under the driver seat. Don't ask why,I wish I knew!!Lol!! I "Several years ago" decided to cut the lines at that location.
Anyways...I'm only replacing the lines from that point forward,and everything from there back,will be the stock 77.5 Na equipment.
I'm very familiar with the 924 Na fuel lines.However,I've seen pics of 931 engine compartments,and seen the fuel filter in a different location"windsheild area". So... I'm assuming the 931 lines are routed dramatically different than the NA.
I'm wanting to know how the fuel lines are routed on the 931. Maybe someone has pics that could help me understand?
Thanks....
Chad _________________ 77.5 Porsche 924/4.9L cadillac swap
Inspector: These brakes look completely inadequate.
Burt Munro: Well, I'm planning on going, not stopping. |
Posted: Wed May 05, 2010 2:19 pm Post subject: |
There way different, thats for sure. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
chad-tanner
Posted: Mon May 10, 2010 4:36 am Post subject: |
Joes924Racer wrote: | There way different, thats for sure. |
Can anyone explain??? _________________ 77.5 Porsche 924/4.9L cadillac swap
Posted: Mon May 10, 2010 5:01 am Post subject: |
well, they are the same.
i'm using 83 NA lines from the tank to the engine compartment...and then 931 lines to go around from one side to the other to feed the CIS. _________________ https://www.the924.com |
Posted: Mon May 10, 2010 5:07 am Post subject: |
Yea there routed onto the other side of the car since the fuel
is., it goes thru a few bulkheads/ panels to get there Chad Tanner. _________________ 1979 porsche 924 Na
Slam
Posted: Thu May 13, 2010 1:27 am Post subject: |
The biggest difference is that the lines head up to the well in front of the driver, where the fuel filter is, then head across the firewall to the battery compartment and down the R/H inner fender. The lines are attached to the windshield mounts. The fuel dizzy is on the R/H side in the 931 cars. If I remember I'll snap some pics for you tonight. _________________ '84 944 - kid blew motor
'80 924 - gone
'78 924 - gone
Posted: Thu May 13, 2010 1:48 am Post subject: |
I'd some pics already -
There they go - up from under the car, to the top-left of the engine compartment, then rearward into the cowl area to the fuel filter, out/past the rear of the filter, across to the other side running below the windshield..
..around the back of the battery at the right side, then forward into the engine compartment again..
Final destination - fuel distributor at engine comp. front-right -
_________________ "..it's made in Germany. You know the Germans always make good stuff."
Slam
Posted: Thu May 13, 2010 3:30 am Post subject: |
3,000 words there.
Slainte! _________________ '84 944 - kid blew motor
'80 924 - gone
'78 924 - gone
