Posted: Sun Jun 28, 2009 10:37 am Post subject: Fitting a Late (Plastic) Fuel Tank to a 924S |
I recently pulled the tank out of Red to check out fuel leakage problems, and sure enough, she was leaking at the stampings on top as typical (discussion at Pelican Parts). The "expansion tank," i.e., plastic tube of mystery was also cracked. Yes, I could have the tank repaired, and get new plastic bits from Germany, but by the time I was done, that would end up costing me two bills.
Coincidentally, a buddy of mine was parting a 951, with the later plastic tank. I jumped on the opportunity to do the swap, rid myself of a leaky, and liner-shedding steel tank, and give myself a hefty 22 gallons of capacity.
The steps are:
- Get tank, pump, filter bracket, trans xmember, tank straps, strap brackets, and standoffs from the donor. Make mounting templates or take measurements for the strap brackets.
- Excise welded in toofah crossmember, magically revealing mounting points for xmember and tank straps (applies to 924S only).
- Weld in brackets, standoffs.
- Install tank, and tranny using updated center "dangle" mount.
Next, introductory pics. . . _________________ Toofah King Bad
- Red (1987 924S) - Pro44/Spec944
Posted: Sun Jun 28, 2009 10:47 am Post subject: |
951 v Toofah, Left End of Crossmember:
Right End of Crossmember:
951 v Toofah Spare Tire Well:
Next, creation of bracket template, removal of strap brackets. . . _________________ Toofah King Bad
Last edited by Rasta Monsta on Sun Jun 28, 2009 11:15 am; edited 1 time in total |
Posted: Sun Jun 28, 2009 10:59 am Post subject: |
Start with a 12x26 piece of cardboard. Jam it tightly into the corner as shown here:
For convenience sake, trim it down to a semi circle. Also remove a bit of the corner if there is a big blob of body sealer/undercoating in the corner of the body:
Brackets, meet Mr. Angry Grinder, and his new friend, The Wire Wheel of Death.
That wire wheel made extremely short work of the undercoating material. Easy breezy!
Next, measure out the positions of the brackets (from TOP and car's RIGHT), and mark them on your template. Now remove the brackets using a spot weld cutter.
With the brackets in hand, their precise shape can be traced onto the template, and holes cut with a box cutter. Double check your work by holding the template in place on the donor car:
Next, turning your x-member into an x-x-member. _________________ Toofah King Bad
ic932
Posted: Sun Jun 28, 2009 7:43 pm Post subject: |
Top Man...excellent write-up Rasta.
I can see you have exciting plans for Red huh? |
mvallee
Posted: Fri Jul 03, 2009 11:49 am Post subject: |
Lookin Good! |
Posted: Mon Jul 06, 2009 4:48 pm Post subject: |
Huge thanks to mvallee, who has answered a bunch of my questions over at Pelican.
Also, he is creating a 951 powered GTS, and if we all bug him about it, he might share some of the details. . .and PICS! _________________ Toofah King Bad
Posted: Fri Jul 24, 2009 2:41 am Post subject: |
And now, to hack out that crossmember.
Did you know they made metal cutting wheels for a Skil saw?
PROTECTION IS EXTREMELY IMPORTANT!
Yeee-haw!
Thankfully, there really were bolt holes under the crossmember!
UGLY v. PRETTY
Whew! Next, prepping and welding in tank mounts. . . _________________ Toofah King Bad
Joined: 01 Oct 2004 Posts: 15427 Location: Woodstock IL
Posted: Sat Aug 08, 2009 2:54 pm Post subject: |
Hey Rasta, I want to add a section in the performance upgrade thread referencing your conversion. Out of curiosity, what was your primary motivation for doing this? I know the plastic tank is lighter and higher capacity, and you had the cracking issue on the original...any other considerations I should mention? Also, how about an update...any recent progress? _________________ 88 924S SE | 82 931 Holbert | 81 Euro 931 | 81 Weissach | 80 US 928 | 80 US 931 '941' | 78 D-Prod Replica | 78 w/D-Prod kit | 78 Poli-Form | 78 Limited Edition |
Chrenan
Posted: Sun Aug 09, 2009 1:09 am Post subject: |
951 tank is HUGE. 90 litres I think. _________________ 1987 951 - M193 Version for Japan |
Joined: 02 Nov 2002 Posts: 9385 Location: Southeast Wisconsin
Posted: Mon Apr 12, 2010 10:10 am Post subject: |
Rasta, is it just me, or are the pictures gone? _________________ White 87 924S "Ghost"
Owned and repaired 924s since 1977 |
Posted: Mon Apr 12, 2010 3:36 pm Post subject: |
Corrected. _________________ Toofah King Bad
Last edited by Rasta Monsta on Tue Apr 13, 2010 11:55 am; edited 1 time in total |
Posted: Tue Apr 13, 2010 10:48 am Post subject: |
C'est bien dommage. _________________ White 87 924S "Ghost"
Posted: Tue Apr 13, 2010 11:11 am Post subject: |
Use the template to mark the area the tank brackets will go on the spare tire well:
Then put Mr. A.G. back to work:
Same for the upper "hanger" mounts, which center perfectly into the round areas stamped into the cargo floor. PLEASE NOTE THAT THE STANDOFFS WERE REMOVED FROM THE SQUARE CUT OFF BITS IN THE PIC BEFORE INSTALLATION.
This guy brought his 120v welder over, and did the job pretty inexpensively:
Next: fuel lines. _________________ Toofah King Bad
Last edited by Rasta Monsta on Tue Apr 13, 2010 11:57 am; edited 1 time in total |
Posted: Tue Apr 13, 2010 11:28 am Post subject: |
Fuel line routing was a bit of a pain, but not insurmountable. First, the feed line, shown here with rubber intermediate line attached:
PLEASE NOTE THAT I SWAPPED THE POSITIONS OF THE FEED AND RETURN LINES IN THE ABOVE BRACKET, AS THE FEED LINE NEEDS TO DROP DOWN AROUND THE FRONT OF THE TANK NEAR HERE. WHEN YOU DO THIS, YOU MUST ALSO INSULATE THE TWO LINES FROM ONE ANOTHER WITH RUBBER AT THE POINT THEY CROSS TO AVOID DAMAGE FROM RUBBING!
On the 951, the fuel filter is mounted on the crossmember, and the feed line to the front of the car (via metal hardlines) leaves it by way of a special fitting, which then transitions into a rubber hose. You can see the rubber section in the stock feed line in the photo, also requiring a special fitting.
These two different ends need to be on the same line, so I fit the crossmember to the car, and used a couple of zip ties to attach the rubber sections to each other, side by side, along the path they would need to take from hardline to filter mount. I then disconnected the lines, and took them (still zip tied together) to the hose shop to have a custom line made up, of the correct length and with the correct ends to "blend" the two systems. Easy peasy!
Next the return line:
The 951 fuel return goes into the TOP of the tank near the sender. In the pic above, the line basically needs to do a 90 degree turn right around that fastener, and along the path of the stamping you can see leaving the top of the pic. I thought about trying to bend the line, but my pals at the hose shop recommended the line be cut, and a compression fitting used instead. A 90 degree barb was then screwed onto the compression fitting, and a piece of hose pressed onto the barb, and attached to the tank on installation.
Next, spend five minutes installing the fuel tank. You can't imagine how much easier this is without that stupid crossmember in the way.
DONE. Red no longer stinks of gas, has a better tranny mount setup, and holds 20+ gallons of fuel. _________________ Toofah King Bad
Last edited by Rasta Monsta on Tue May 11, 2010 5:14 am; edited 7 times in total |
Posted: Tue Apr 13, 2010 11:37 am Post subject: |
Merci beaucoup! _________________ White 87 924S "Ghost"
