stv951
Posted: Wed Jan 20, 2010 6:58 pm Post subject: Short Ratio C&P for 924 S |
Hello guys,
anyone knows what is the shortest crown and pinion that can be installed on a 924S that is used for hllclimbs and shorts tracks ?
Can I use one from an Audi or is ony Porsche unit available with short final ratio ? I need the shortest available
TIA |
v8carreragts
Posted: Thu Jan 21, 2010 8:16 am Post subject: |
I believe the 4:11 used in the 80-82 US 924 would fit. |
stv951
Posted: Tue Jan 26, 2010 6:01 am Post subject: |
Interesting !!! Anyone to confirm this before i go out and buy it please ? |
stv951
Posted: Thu Feb 04, 2010 7:43 am Post subject: |
Bumper ! |
Andrew NZ
Posted: Thu Feb 04, 2010 3:46 pm Post subject: |
I've just bought a 4.78:1 out of an audi diesel, but won't know for sure if it'll fit for a few weeks. Will let you know when I've tried it. _________________ Andrew
1977 RX924 race car
12a bridgeport supercharged
www.race4-dcup.co.nz |
v8carreragts
Posted: Fri Feb 05, 2010 7:16 am Post subject: |
They should both work. The only ones they won't fit is the 944 S/S2 and 951. In these the front pinion bearing is larger and the pinion shaft is 4mm longer than all previous 016's. |
stv951
Posted: Tue Feb 23, 2010 7:06 am Post subject: |
Andrew NZ wrote: | I've just bought a 4.78:1 out of an audi diesel, but won't know for sure if it'll fit for a few weeks. Will let you know when I've tried it. |
hello Andrew,
what gearbox have you got ?
Which audi did this come from ?
I am very interested as if you managed to install it.
Please let me know |
stv951
Posted: Mon Mar 08, 2010 9:12 am Post subject: |
Bump |
stv951
Posted: Mon Mar 27, 2017 7:04 am Post subject: |
bumpie... _________________ Steve
931 81 177 bhp White
931 81 0 bhp engineless Platinum
924S 86 stripped with cage for Track days Red
944 83 Auto Blk
924 84 project 924 CGTS with 951 running gear
944 S2 90 Convertible 3xBlack
951S 91 Vitesse stg 3 350 bhp |
kevingross
Joined: 15 Apr 2015 Posts: 34 Location: Stow, MA, USA
Posted: Sun May 07, 2017 8:34 am Post subject: |
Yes, the shorter ratios will work in the 924S transmission if you can find them. NLA for many years from Audi/VW. My advice if you can find one:
- Have it tested before installing, especially the pinion gear. I use a dye penetrant test (Magnaflux makes the kit I use) which will reveal surface cracking.
- Have the pinion depth set using the factory VW385 tool set. Correct set-up is critical to keeping the pinion from breaking. Bluing or eyeballing it doesn't work.
Good luck! _________________ Kevin
Catellus Engineering, Inc.
http://www.catellusengineering.com/
catelluseng@gmail.com |
