head removal
windwaiver
PostPosted: Thu Jan 21, 2010 2:22 am    Post subject: head removal Reply with quote
Ok, is it common knowledge to always have the head resurfaced everytime you remove it? I want to replace the rings and mains in this car, I had the head done about 10k miles ago. oh its a 82 924 NA.
77.5 924 NA
81 924 na (great parts car)
82 924 NA
87 944S this is gonna cost
00 K1200LT
If i had a nickel for everytime I screwed up.......
!tom
PostPosted: Thu Jan 21, 2010 2:26 am    Post subject: Reply with quote
Only if it needs it.
Check the head for flatness (with a straight edge). If it isn't flat, it needs to be machined. If there's been a head gasket failure, it may need to be machined (depending on the nature of the failure).
If the head already meets flatness specifications, then machining it is both a waste of the head's life and your money. It might be good for the economy though.
78 924 NA
5-lug
PostPosted: Thu Jan 21, 2010 2:54 am    Post subject: Reply with quote
+1^
To emphasize Tom's point, these heads are notorious for not having sufficient head height, so only machine it if you absolutely must. When I did my top end rebuild on the NA after its head gasket failure, I didn't need to machine it. But my failure was a very gradual one, not a catastrophic blow out. YMMV.
Here are the specs:
Permissible unevenness of mating face: 0.1 mm
Max. reworking depth 0.4 mm
Peak-to-valley height = 0.015 mm
Head height = 139.55mm
Page 8 of the 924 Tech Specs booklet, complete with illustration of how to measure.
