Chrenan
Posted: Tue Aug 01, 2006 7:27 am Post subject: How to rebuild an engine - a pictoral journal |
Spare engine removed from parts car
Spare engine on stand
Head removed from spare engine - bottom
Head removed from spare engine – intake side
Head removed from spare engine – exhaust side
Head removed from spare engine - front
Head removed from spare engine - back
Head back from European Motorworks (Eurorace) - 44/37 mm valves & Stage 1 cam - bottom
Head back from European Motorworks (Eurorace) - 44/37 mm valves & Stage 1 cam - intake
Head back from European Motorworks (Eurorace) - 44/37 mm valves & Stage 1 cam - exhaust
Head back from European Motorworks (Eurorace) - 44/37 mm valves & Stage 1 cam - valves
Head back from European Motorworks (Eurorace) - 44/37 mm valves & Stage 1 cam - springs
Head back from European Motorworks (Eurorace) - 44/37 mm valves & Stage 1 cam – cam
Head back from European Motorworks (Eurorace) - 44/37 mm valves & Stage 1 cam – top
Bottom end disassembly
Bottom end disassembly – caps removed
Bottom end disassembly – crank and pistons removed
Bottom end disassembly – top
Block back from machine shop – top exhaust side
Block back from machine shop – top intake side
Block back from machine shop – bottom exhaust side
Block back from machine shop – bores
Bottom end assembly – crank
Bottom end assembly – oil pickup
Bottom end assembly – 9.3:1 euro spec pistons
Bottom end assembly – rear crank seal
Bottom end assembly – oil pump and front crank seal
Bottom end assembly – oil pan intake side
Bottom end assembly – oil pan exhaust side
Bottom end assembly – oil pan front
Bottom end assembly – oil pan back
Bottom end assembly – crankcase breather
Bottom end assembly – water pump and alternator brackets
Bottom end assembly – alternator bushings
Head assembly – block off plate and fuel line holder
Head assembly – distributor housing
Head assembly – coolant flange
Head assembly – thermo time switch and temperature sender
Head assembly – oil pressure sender
Head assembly – thermostat housing
Head assembly – front seal
Head assembly – cam pulley
Head assembly – head mated to block
Engine assembly – coolant transfer tube and intake side engine mount
Engine assembly – rear coolant hoses
Engine assembly – exhaust side engine mount
Engine assembly – exhaust studs
Engine assembly – exhaust manifold
Engine assembly – timing belt and crank pulley
Engine assembly – intake manifold
Engine assembly – throttle body
Engine assembly – warm-up regulator
Engine assembly – auxiliary air valve
Engine assembly – cold start valve
Engine assembly – injectors
Engine assembly – clutch bracket
Engine assembly – thermostat upper housing and bleeder hose
Engine in place
Engine fully installed _________________ 1987 951 - M193 Version for Japan |
Lizard
Posted: Tue Aug 01, 2006 9:00 am Post subject: |
I like your badge replacement, cannot be lifted by petty thieves. _________________ 3 928s, |
Chrenan
Posted: Tue Aug 01, 2006 10:51 am Post subject: |
It was a previous owner modification, probably the only good thing he did for the car. When I put it back to the original colour it will be totally de-badged, I like the clean look. _________________ 1987 951 - M193 Version for Japan |
Posted: Wed Apr 29, 2009 11:18 pm Post subject: |
Chrenan, did you have Eurorace do any porting, or was it simply the valve work and assembly of the head?
Also, on your Audi 5000 big bore throttle body, have you had any longevity issues with the fitment of the stock 924 rubber boot that mounts directly to the TB? _________________ erstwhile owner of just about every 924 variant ever made |
Rich H
Posted: Wed Apr 29, 2009 11:57 pm Post subject: |
Awesome!
Shame it's hidden in the engine bay!
did you skim the block to up the CR any?
I had a big audi TB, while the intake pipe was a squeeze it was perfectly adequate and suffered no ill effects from being stretched over.. _________________ 1994 Lotus Esprit S4 - Work in progress...
Chrenan
Posted: Thu Apr 30, 2009 12:35 am Post subject: |
Nope, didn't skim the block at all. It was a fairly mild build. I'm happy with how it turned out, still running strong, pulls really well.
I still have the engine that came out of the car, so when I have the time and inlcination, that one will be bored out, stroker crank, custom pistons and either another big valve head or a 931 head. _________________ 1987 951 - M193 Version for Japan |
Posted: Thu Apr 30, 2009 12:37 am Post subject: |
ideola wrote: | Chrenan, did you have Eurorace do any porting, or was it simply the valve work and assembly of the head?
Also, on your Audi 5000 big bore throttle body, have you had any longevity issues with the fitment of the stock 924 rubber boot that mounts directly to the TB? |
Chrenan
Posted: Thu Apr 30, 2009 11:26 am Post subject: |
Ports were hogged open as well I believe, not actually sure, old school 80's techniques .
The same rubber boot has been on since the engine went together, it was new on installation and shows no adverse wear from the larger throttle body. _________________ 1987 951 - M193 Version for Japan |
Power Tryp
Joined: 16 Apr 2009 Posts: 434 Location: Calgary, Alberta
Posted: Thu Apr 30, 2009 3:02 pm Post subject: |
Any plans in place to get it dyno'd? I know I for one would love to see what kind of power it makes. I am a bit on the biased side of that having worked closely with the owner of dynoplus (engine dyno only) and being friends with the owner of SCP (engine and two wheel chassis dyno) here in Calgary.
Tryp _________________ Melanie - 1980 931
NoName - 1980 931 (seeking rebuild)
Green tartan interior, you don't see that on a Civic. |
Chrenan
Posted: Fri May 01, 2009 12:01 am Post subject: |
No plans to get it dynoed, but it would be interesting. I'd have to find a dyno that reads that low! _________________ 1987 951 - M193 Version for Japan |
Power Tryp
Posted: Fri May 01, 2009 3:25 pm Post subject: |
Oh i'm sure it'd be no problem, if they can find out the power of a smart car then i'm sure they can find out what power yours makes. Personally I'm not interested in the HP from your engine, I wana see the torque #s that It produces.
smither
Joined: 03 May 2009 Posts: 26 Location: Pontyclun, Wales, UK
Posted: Mon Oct 12, 2009 1:23 am Post subject: |
Hi Chrenan
Really great pictures, i was looking at the exhaust ports on your new big valve head and it seemed to me that they had been enlarged and rounded off. I also noticed that you appeared to use a stock exhaust manifold (i think you call them headers in the US), could you tell me what gaskets you used and if you did anything to them to match the ports?
Thanks _________________ 1978 NA 924 dogleg
1971 Triumph Gitfire with ashley hardtop
2000 MGF (for the wife) |
