turbozetec
Joined: 06 Mar 2009 Posts: 10 Location: woodstock, va
Posted: Fri Sep 04, 2009 8:04 am Post subject: 79 924 to 87 924s |
I know this probally has been posted before I tryed to search for it but could find what im looking for. I have a 79 924 and Im buying a recked 87 924s how hard will it be to switch out everything into my 79. Im wanting to change the suspension to the 5 lug and swap motors and transaxels. Will the 87 924s engine bolt right in or with little modifications. Has anybody done this before? |
chad-tanner
Joined: 23 Mar 2008 Posts: 217 Location: New Madrid,MO
Posted: Sat Sep 05, 2009 4:26 am Post subject: |
I was hoping someone else would answer this,but I'll try to help and also save you from being reamed by the search gestapo.
Anything is possiable,you can swap a Merlin V12 aircraft engine into a 55 chevy sedan,(it's a fact)
As for bolting a engine into the 924,I doubt you will bolt a 2.5L,3.0L or anything other than the 2.0L audi into a early 924.However I did see some pics on this board,of someone doing that swap.I think that thread was in the genral discussion or maybe the performance section of this board.Someone else may be able to help you locate that thread.
It's only my opinion,but I'm sure you could buy a pretty nice 944 for what you would invest in a engine swap. _________________ 77.5 Porsche 924/4.9L cadillac swap
Inspector: These brakes look completely inadequate.
Burt Munro: Well, I'm planning on going, not stopping. |
AppleBit
v8carreragts
Posted: Tue Sep 08, 2009 9:37 am Post subject: |
The suspension will bolt in
The engine will need holes drilled into the 79 crossmember for the late motor mount studs.
The hydraulid clutch parts will bolt in from the late car. The 79 should have the dimple in the left wheelwell for the clutch master cylinder and the pedal return spring mount should also be there. You will need the clip with the studs from the late car. This is what the clutch master cylinder nuts attach to. (79 was the first year for the 924 turbo which used the same clutch mech)
I believe the late 924's used the same transaxle mounting so this should bolt in as well.
The ECM can be mounted under the steering column just as in the late car by using tha late brackets. You will need to cut a hole in the firewall for the engine harness.
You will need to mount the ign. coil to the right fenderwell. You could probably drill out the spot welds on the late bracket and bolt or pop rivit it to the early car.
You will need to modify the fuel line ends to attach to the late fuel system.
The only thing you will need to do soome modification to is the radiator mount because the late radiator is larger than the early one.
I think that just about covers it. I did this to the 79 I used to have. |
turbozetec
Posted: Sun Oct 04, 2009 2:22 pm Post subject: |
Well I just got a good deal on a 87 924s that was hit in the front end and Ill be transplanting the drive train and suspension into my 79. It will be nice to have a 2.5 efi motor. |
