924martinirossi Guest
Posted: Thu Aug 29, 2002 12:47 pm Post subject: |
Todays Findings:
Lots of foam air cleaner type material in bottom of gas tank. Removed.
In tank pump very defective and lost it's screen filter, also removed.
Pin 10(12) of Control Unit Acceleration Enrichment module is shorted to ground. Removed throttle body and adjusted.
Found on wire on the above module that IAW manual s/b on pin 5(12), however it is on pin 7(12)
Found pin 5(12) and 11(12) are jumpered to ground.
3mm vacume lines are all orginal with the funkey squeeze clamps. Very brittle, bought 6ft. of new line.
Hooked up spare in-tank pump to my digital powersupply and it pulls .22Amps at 12.51Vdc.
In-tank pump, external pump and associated wiring pull a total of 6.52Amps at 13.30Vdc.
Purolator PM4193 filter is attached to spare in-tank filter.
Also lots of plastic and metal shavings were found in the bottom of the gas tank.
I also need someone to verify some wiring of the Control Unit Accelator Enrichment module. I need for a lister to actually pull both the 12 and 8 pin connector and identify the wire colors as the book is wrong or the car was wired wrong.
Michael |
Posted: Thu Aug 29, 2002 12:49 pm Post subject: |
Car is a 1981 Turbo. Wirung for the above post was checked aganist Chapter 13, figure 13.14 of the Haynes Manual.
Michael |
Zuffen
Joined: 31 Jul 2001 Posts: 1426 Location: Owasso, Oklahoma 74055
Posted: Thu Aug 29, 2002 12:55 pm Post subject: |
Don't trust any book on the wire coding. Only trust the year model update book and the manual supplements for that year in question.
How do I know, try to find a faulty relay in the AC and trace in through 4 books and finally found a diagram I could trust. And it was the last relay I didn't check after giving up for a week and doing some brainstorming.
Zuffen
Posted: Thu Aug 29, 2002 2:28 pm Post subject: |
WKD 450.021
is the service information for model 81
There is a wiring diagram (page 45) for the OXY/ign/timng control/aceleration enrichment CU and but no color codes
Zuffen
Posted: Thu Aug 29, 2002 2:31 pm Post subject: |
8 goes to fuse 16 amp number two, unkown block
12 goes to temp switch
Zuffen
Posted: Thu Aug 29, 2002 2:37 pm Post subject: |
"I also need someone to verify some wiring of the Control Unit Accelator Enrichment module. I need for a lister to actually pull both the 12 and 8 pin connector and identify the wire colors as the book is wrong or the car was wired wrong."
Found the wire diagram.
12 bl/re to temp switch from CU ACC enrich
8 re/ye from oxs control unit
8 re/ye from CU ACC Enrich
