ReMo
Posted: Wed May 13, 2009 4:08 pm Post subject: Question about fuel accumulator |
I want t o replace my fuel accumulator. I bought a used one.
The seller told me that he was good, but there is fuel inside the accumulator. When i remove the screw at the bottom, fuel is coming out.
Is this normal?
Crux Mason
Posted: Wed May 13, 2009 4:32 pm Post subject: |
| I was told it is shot if fuel comes out the bottom. That is the next part I am going to be taking off my car along with the second fuel pump since I got the in tank one out. I got 6 gallons of whiskey colored gas out so I am not holding out too much hope for it. If anyone has a accumulators for sale I am sure I will want it, just not it leaks of course. |
ReMo
Posted: Wed May 13, 2009 5:16 pm Post subject: |
I asked a firm who sells 924parts too. They say that it is normal.
One problem, different answers.
dpw928
Posted: Wed May 13, 2009 11:18 pm Post subject: |
If fuel comes out of the screw side that means the internal diaphram is bad and leaking fuel. Get a refund.
78 928 5 sp Silver
78 928 AT Euro Black |
Chrenan
Posted: Thu May 14, 2009 12:11 am Post subject: |
| ReMo wrote: | | I asked a firm who sells 924parts too. They say that it is normal. |
That is normal, for a bad accumulator. _________________ 1987 951 - M193 Version for Japan |
Posted: Thu May 14, 2009 12:39 am Post subject: |
| ReMo wrote: | | I asked a firm who sells 924parts too. |
Recommend not asking them anything else. _________________ Toofah King Bad
Posted: Thu May 14, 2009 9:55 am Post subject: Re: Question about fuel accumulator |
| ReMo wrote: | | The seller told me that he was good, |
Technically he didn't lie, as long as he wasn't leaking too. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Mike924
Posted: Fri May 15, 2009 4:30 am Post subject: |
The conclusion I've reached from my own observations is that the diaphragm starts to leak not because it's punctured, but simply because it becomes porous with time (20 yrs +).
Hence, it is a risky thing to buy a used accumulator of any vintage.
I think the only viable solution is to swallow the cost and buy a new one. I know 924 ones (with the different size connections) are hard to find. That is why I modified my pipe work to use the same size (larger) output connector so that VW (Golf) or Ford (ugh!) units can be used.
(BTW fitting a new (VW) accumulator solved my hot start problem.) _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
