2Fast
Joined: 09 Dec 2007 Posts: 459 Location: Klamath Falls, OR
Posted: Wed Mar 25, 2009 7:56 am Post subject: Would this product work for a exhaust gasket(s)? |
Any reason why this product wouldn't work for some exhaust gaskes on the 2.0???? The original gaskets had metal on them, i'm not sure if this material does or not. http://www.amazon.com/Mr-Gasket-5960-Ultra-Exhaust/dp/B000BWAPHA/ref=pd_sbs_auto_1 _________________ =====>Alex<=====
1979 Porsche 924 NA 5spd
1979 Parts Porshce 924 NA 5spd |
968rz
Joined: 21 Aug 2006 Posts: 537 Location: S. E. Wisconsin
Posted: Wed Mar 25, 2009 11:52 am Post subject: |
I use it on the flange between the cat and header pipe. It has to be tight (no leaks) or it will fail fast. _________________ Rick
79 924 coupe Petrol Blue 3spd auto (wife's DD)
93 968 coupe Amazon Green 4spd Tip (my DD) |
2Fast
Posted: Wed Mar 25, 2009 12:32 pm Post subject: |
| 968rz wrote: | | I use it on the flange between the cat and header pipe. It has to be tight (no leaks) or it will fail fast. | Oh thats cool it would work there! How well do you think it would work inbetween the manifold and the head? And also inbetween the manifold and the down pipe? Because those are the Two places i need to replace the gaskets. If it works for those two places, i'll purchase it and then i can patch up the cat area too. _________________ =====>Alex<=====
968rz
Posted: Wed Mar 25, 2009 2:46 pm Post subject: |
It should be fine there but like I said, it needs to be leak free or the hot exhaust will eat it away fast. _________________ Rick
Nobbi
Posted: Wed Mar 25, 2009 7:38 pm Post subject: |
i am pretty sure you get the original gasket for just a two dollars more!  _________________ NA 924 - april/1977- 4-speed-audi gearbox.
500.000 km with fun.....and new toy:Porsche 944 S2 Cabriolet.Other car Daimler c-class cabby,brandnew..Plus : DEUTZ 4005 tractor Built 1967 |
2Fast
Posted: Thu Mar 26, 2009 1:39 pm Post subject: |
| Nobbi wrote: | i am pretty sure you get the original gasket for just a two dollars more!  | Oh man, I know, its just tough trying to get my headgasket replaced and keep the cost down. . Oh and Rick, thanks for the info, if I do decide to go with the gasket paper, i'll keep that in mind  _________________ =====>Alex<=====
