Vacuum routing w/o emissions??
CorsePerVita
PostPosted: Sat Mar 14, 2009 9:56 am    Post subject: Vacuum routing w/o emissions?? Reply with quote
So i found some vacuum routing diagrams. However... i no longer have emissions, so everything that went with it and all the hoses are gone. I got new vacuum line, new ends so I could attach and seal them. I was wondering if anyone had a diagram for vacuum routing without the weird emissions routing.
I'm assuming the green tube coming from inside the fender is the "vacuum reservoir" and then i have 3 other spots for vacuum. Should I plug some of them? Do i need the vacuum amplifier even now that i don't have emissions?
F'in hate vacuum lines.
- 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
Ozzie
PostPosted: Sat Mar 14, 2009 7:00 pm    Post subject: Reply with quote
This is all I have on mine
( I have re-routed the breather hose to the air box and sealed the join in the boots since)
Its AUTO and its BLACK
Montego Black on black/red
CorsePerVita
PostPosted: Sun Mar 15, 2009 6:10 am    Post subject: Reply with quote
i have a 77' i'm not aware of an aux air valve? i'll look again. right now the only thing i have hooked up is from the throttle body to the distributor, the back of the distributor is going back into part of the intake manifold.
- 1999 Ducati 900SS
Ozzie
PostPosted: Sun Mar 15, 2009 7:39 am    Post subject: Reply with quote
This is a ROW car. Only has one line to the dist and AFAIK all car had an AAV if you have CIS.
