mcadam1121
Posted: Wed Dec 17, 2008 2:21 pm Post subject: clutch choice for v8 swap |
this is for the people that have done a v8 swap and run the transaxle
what did you do for clutch discs
that is really the on part that would be hard if you wanted to use the stock torque tube
did u find a clutch disc the rite size or did you have to have one made _________________ The Ginger
77 porsche 924 Martini |
Posted: Thu Dec 18, 2008 12:26 am Post subject: |
You should contact Porschev via PM. Also, here's some RECOMMENDED READING where Porschev and MacBDog discuss related issues for Mac's recent V8 conversion. _________________ erstwhile owner of just about every 924 variant ever made |
v8carreragts
Posted: Thu Dec 18, 2008 6:28 am Post subject: |
If you have a 924 turbo/944 all you need is a Chrysler disc. Any one with a 1" x 23 spline. They make them up to 12"
If you have a 924 N/A (early) you are stuck with a 9 1/4" Ford disc. (13/16 x 24 spline) |
mcadam1121
Posted: Thu Dec 18, 2008 10:14 am Post subject: |
What years on the cryslers and fords also what vehicles _________________ The Ginger
alexvex
Joined: 31 Jul 2006 Posts: 420 Location: Seattle, WA (from Indiana)
Posted: Thu Dec 18, 2008 11:10 am Post subject: |
I believe the ford is a bronco clutch..do a search, it's been covered. _________________ --Alex--
1992 Porsche 968 (VW 2.5L I5 Turbo swap in the works)
1995 Audi 90 Quattro Sport (4.2L V8 Swap)
2010 Touareg TDI
Past Pcars: 80 931, 87 924S, 87 951 |
mcadam1121
Posted: Sat Dec 20, 2008 4:03 pm Post subject: |
Well I looked it up and I believe a Chevy v8 uses a 11 3/8 disc if u use the 944 tranny with the 1"shaft.& 23 splines a disc out of a 85 dodge 1/2 ton will fit perfectly _________________ The Ginger
