Question for EFI Gurus: To Return or Not to Return
PostPosted: Tue Dec 09, 2008 12:15 am    Post subject: Question for EFI Gurus: To Return or Not to Return Reply with quote
Hey, EFI guys, what are you running on your fuel delivery system: a fuel return as with the stock setup, or are you running returnless? Can't you just eliminate the return line to the fuel tank? All of the "endwrench" rails I've seen are setup with a port on both ends, so I'm assuming these have all been setup with a return to the fuel tank? I'm trying to ascertain why a return-based setup would be required if you're running EFI.
PostPosted: Tue Dec 09, 2008 1:00 am    Post subject: Reply with quote
Umm....because the pressure in the fuel rail would never be constant...it depends on how much you "bleed" into the engine so you cant calculate the amount of fuel or pressure the fuel pump must pump....and even if you could...you'd have to open loop regulate the pump.
The pump always puts out the same amount of flow and the FP regulator bleeds the excess into the tank.
IE: the pump puts out a max flow matching the need of the engine at 6000RPM...if the pump would output the same flow at idle the pressure in the fuel rail would increase and blow up or at least make the idle mixture very rich.
Rich H
PostPosted: Tue Dec 09, 2008 1:10 am    Post subject: Reply with quote
Please please please run a return setup.
Problem is that without a return regulated rail you have fuel sitting in the rail all the time and it gets hotter and hotter and hotter as it never gets cooled by fuel flowing through it all the time. With a return you get a cool flow all the time, without you only flow the bit the injectors use.
You will still need a fuel pressure regulator somewhere, you have to regulate the fuel pressure in the rail somehow.
run a return
PostPosted: Tue Dec 09, 2008 1:15 am    Post subject: Reply with quote
Got it. I was planning to run a return-based setup, but somebody asked me why and I didn't know how to answer.
So how do the returnless systems work? This is just for my own personal edification.
Rich H
PostPosted: Tue Dec 09, 2008 1:30 am    Post subject: Reply with quote
The regulator works in the feed line and bleeds pressure off it there, achieves the same effect but you don't get the through flow at low throttle.
At higher throttle the injectors grab enough fuel to create enough flow to cool the rail.
Min
PostPosted: Tue Dec 09, 2008 2:04 am    Post subject: Reply with quote
fairly sure returnless systems regulate rail pressure by changing the speed of the fuel pump. Which just complicates control, the entire point of a returnless system is to control emissions, so no real benefit to running one.
Min
Rich H
PostPosted: Tue Dec 09, 2008 2:36 am    Post subject: Reply with quote
Min
Won't someone please think of the children!!
Emissions results are in:
Volcanos 1, Man 0
Raceboy
PostPosted: Tue Dec 09, 2008 4:19 am    Post subject: Reply with quote
Returnless fuel system relies on PWM-ed fuel pump but that is pretty much out of the question for do-it-yourselfer car enthusiast.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
PostPosted: Tue Dec 09, 2008 5:25 am    Post subject: Reply with quote
"Pulse Width Modulation" - to answer an imaginary next question.
PostPosted: Tue Dec 09, 2008 5:52 am    Post subject: Reply with quote
My DTA Fast unit supports PWM...
Martijnus
PostPosted: Tue Dec 09, 2008 6:11 am    Post subject: Reply with quote
is that enough reason to go returnless?
the return lines are there anyway
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
PostPosted: Tue Dec 09, 2008 6:29 am    Post subject: Reply with quote
But they're not E85 safe I have to replace them with teflon-lined braided stainless, which ain't exactly cheap.
bass gt
PostPosted: Tue Dec 09, 2008 6:35 am    Post subject: Reply with quote
Dan,
seriously, run a return'd system. The fuel pressure reg sits on the retun end of the fuel rail, and keeps the rail pressure constant. Even small voltage changes will affect the pump, which will wreck the fuelling. It also makes the regs job of raising the fuel pressure in line with boost a lot easier.
Finally, air bubbles aren't trapped in the rail, and that can lead to serious issues
Steve
Front Wheel Drive is the Devil's work.
Min
PostPosted: Tue Dec 09, 2008 6:40 am    Post subject: Reply with quote
sure, but does it support PWM as well as detection of fuel rail pressure and is it programmed to change the PWM based on the fuel rail pressure constantly? MS and alot of other systems support "PWM"(can be used for things like boost controllers and idle air valves) but thats entirely different from supporting a returnless fuel delivery setup.
Min
yes yes, will do...again, just asking the question because I didn't know how to answer the question that was asked of me...he specializes in high output Rustangs, and apparently the fuel systems they're installing are returnless. He thought it was unnecessary, but I didn't know how to explain why it should be return-based as opposed to not...
