Posted: Wed Mar 15, 2006 5:05 am Post subject: Audi shift lever refurb |
The shifter for Audi-based gearboxes has a pin that wears to an egg shape over time.
As it wears, the lever feels sloppier and eventually shifting into reverse becomes difficult.
The fix involves cutting off the old worn pin,
drilling and tapping for an M10x1.5 partially threaded bolt,
grinding down the head of the bolt some,
drilling-tapping the edge of the lever for a setscrew,
and reassembly with threadlocker.
showing worn, egg-shaped pin and a 10mm bolt -
shifter after the worn pin was cut off and the area ground flat -
using a drill press to get a clean, straight hole (a slightly undersize bit was used) -
starting the tapping with the same setup, but with the drill having been replaced by the tap -
now the drill press is powered by hand for a few turns to start the tap in straight -
finished the tapping with a T-handle -
found a partially-threaded M10x1.50x50mm bolt and went with it instead of the fully threaded version -
miscellaneous width and length details -
the edge of the shifter was later drilled & tapped for a small setscrew to immobilize the M10 bolt -
used a short piece of re-bar to hammer on while reinstalling the lever -
the shifter boot got some attention while I was in the area -
the original topic on it - http://www.924board.org/viewtopic.php?t=14560 _________________ "..it's made in Germany. You know the Germans always make good stuff."
Min
Posted: Thu Feb 15, 2007 6:19 am Post subject: |
I did a modification like this awhile back (read 5-6 years) and the bolt I replaced the pin with eventually worn the shift rod down enough that I had more slop in my shift than before.
To fix this I machined a new peice out of mild steel that would fit skate board bearings(608z), cut the end off the old shift rod, installed(welded) my new machined peice, pressed some bearings into it, and reassembled. Now when things wear out, I can just replace whatever did (bearings or bolt) Its all very very tight now.
Just gotta upgrade the linkage on the tranny now.
Jakkq
Joined: 29 Sep 2008 Posts: 810 Location: Omaha, Nebraska
Posted: Fri Nov 07, 2008 4:58 am Post subject: |
I knew there was some reason It took 5 minutes to get into reverse the other day! Damn. I'll have to look into this idea. Thanks for this information.
How do I get down to getting the shifter out? Maybe I'm just missing it. _________________ 1979 Porsche 924- Snailshell
http://porsche924workblog.blogspot.com/ |
!tom
Posted: Fri Nov 07, 2008 7:32 am Post subject: |
I believe the '79 comes with the Snailshell transmission, which is different than the Audi unit described here, complete with different shift linkages. _________________ 78 924 NA
5-lug |
Rich H
Posted: Fri Nov 07, 2008 6:28 pm Post subject: |
Min wrote: | I did a modification like this awhile back (read 5-6 years) and the bolt I replaced the pin with eventually worn the shift rod down enough that I had more slop in my shift than before.
Min |
Pics? Both bits are worn on mine.
For bearings in the UK I have used simplybearings.co.uk
very very good site with all bearings in all sizes.
I have replaced the plastic blcok on the tranny with ali bar drilled out but I couldn't find a decently priced 15mm reamer so there is still a bit of slop sadly. I'll make another one day.... _________________ 1994 Lotus Esprit S4 - Work in progress...
Min
Posted: Sun Nov 16, 2008 2:23 pm Post subject: |
Rich H wrote: | Pics? Both bits are worn on mine. |
I suppose I could open it up and take some pictures, I need a better camera, there is alot of goodies I need to take pictures of.
Min
Posted: Mon Oct 18, 2010 2:47 am Post subject: |
Ok, here are the pictures I promised, I notice people are still replacing their shifter pins with bolts, because the bolt material is much harder than the rest of the shift linkage it accelerates wear. The below pictures are the solution.
All bolted together, the way its been since I installed it. I have not had to do any maintenance on this at all since I put it in (years ago). This is the first time its been apart.
First bearing revealed. As you can see its been pressed in. (which was done on the car using a C clamp)
Here is the hole I threaded into the shifter. I threaded this, and also used a nylock nut on the other side to act as a jam nut and a lock nut, it did not come loose at all since I installed it, and it was still very tight when I took it apart for pictures.
The other side, I cut off the bolt because I didn't have one the right length at the time. When installed I used some large washers between the shifter and the bearings on both sides, so that if the washers wore I could just replace them. I made this piece on my lathe, and then welded it in place while the shift rod was in the car (welding looks like crap, didn't intend to show it to anyone and the mig used wasn't very nice).
Rich H
Posted: Mon Oct 18, 2010 3:03 am Post subject: |
Wow, better late than never! _________________ 1994 Lotus Esprit S4 - Work in progress...
Min
Posted: Mon Oct 18, 2010 3:30 am Post subject: |
:p
KDJones2000
Posted: Mon Oct 18, 2010 6:33 am Post subject: |
This fix has been around since 2003, and is an inexpensive fix that can easily be renewed if the bushings wear out:
http://www.dietersmotorsports.com/tech/tech-july-03.htm
You can actually do this entirely inside of the car, just pull the rod up enough to drill it out above your console.
I did this on my car, and it's been great for the past 3 or so years.
Cheers, Keith _________________ 1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S |
Min
Posted: Mon Oct 18, 2010 3:19 pm Post subject: |
KDJones2000 wrote: | You can actually do this entirely inside of the car, just pull the rod up enough to drill it out above your console. |
In my case the pin in the lever had already gone oblong shaped and in the process had made a mess of the shifter rod. Your suggestion is good if things aren't totally goofed by the time you open it up.
PopUpProject
Posted: Fri Sep 05, 2025 11:09 pm Post subject: |
KDJones2000 wrote: | This fix has been around since 2003, and is an inexpensive fix that can easily be renewed if the bushings wear out:
Cheers, Keith |
Very sad this link is dead because I will be working on my sloppy shifter here shortly with some new shifter arm hardware and linkage arm. But between the above posts and the instructions on only944 I *think* I'll be able to figure it out. _________________ Just trying my best to figure this out without total failure
Poppy the '82 924 Resurrection in Progress |
