How to Install a Rear Sway Bar on a 924 without one
Goto page Previous  1, 2, 3, 4, 5  Next
PostPosted: Wed Oct 29, 2008 6:45 pm    Post subject: Reply with quote
Excellent info Peter, thank you.
Now when the factory sells out it will be easier to make your own. Or, if like me consider $45 for a bent bit of 50 x 3 flat bar with 2 holes a rip can avoid the factory ones. Thought they were like $22 but thats US and a big difference now.
Is there any logical reason why the legs are reduced to 30mm? Quicker to weld? less heat? naa. Oh the length of the legs please Peter? Unless there`s good purpose to grinding 50mm to 30 will use 50 bar. Easier to set up square when welding and stronger than 60% of the same weld bead.
We need to get the precise location and angle that these are attached to the torsion bar tube from someone who has them factory fitted.
924guy
PostPosted: Thu Oct 30, 2008 1:02 am    Post subject: Reply with quote
took some basic measurement from the 84 944, in inches, pics follow:
some may be a bit difficult to see, i just put a straight edge ruler up against various points to see where the center and edges are..let me know if more detail is needed, i can always crawl under there again with in the next few weeks until i finsih stripping it and dispose of the carcass..
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
PostPosted: Thu Oct 30, 2008 9:44 am    Post subject: Reply with quote
I've updated the pic with the length of the legs. The height of the mount from highest point to the end of the legs is 44mm.
PostPosted: Fri Oct 31, 2008 11:39 am    Post subject: Reply with quote
I just ran across this on my PC that might be helpful:
PostPosted: Fri Nov 07, 2008 9:36 am    Post subject: Reply with quote
leadfoot wrote:
Whiteline sell brackets to mount the rear swaybar - KU3 universal fits the best, and you can use 14mm poly bushes with it...
Quote from local AutoOne store:
KU3 ~AUD$60
W0400-14 ~AUD$20
AUD$80 - job done.
Sounds like that's considerably cheaper than a stock setup.
Peter_in_AU wrote:
The prices were slightly higher due to the Aussie dollar now being worth two flat rocks rather than three; 113 411 333 (clamp) AU$9.50 each, 477 501 095 (clip) AU$44.65 each but the real shock was the rubber bushes (477 411 313 C) at AU$37.70 each
PostPosted: Fri Nov 07, 2008 3:53 pm    Post subject: Reply with quote
Cool. Post some pics when you get them.
PostPosted: Wed Nov 26, 2008 12:43 pm    Post subject: Reply with quote
Came to AUD$76.20. They didn't have the whiteline bushes, so got Nolathane instead - red instead of white - whatever...
Now all I need is that rear sway... Dan...
PostPosted: Wed Nov 26, 2008 1:04 pm    Post subject: Reply with quote
It just went into a big long box with Peter's torque tube this evening
I'm still trying to track down one early set of spindles and hubs. Otherwise, the only thing left to do is build the crates for the two transaxles. I started work tonight on the parts lists, and should have that done by tomorrow. After our Thanksgiving Holiday this weekend, I should be ready to weigh everything and schedule the drop off at the forwarders
PostPosted: Fri Aug 21, 2009 8:09 pm    Post subject: Reply with quote
Have you fitted these yet Gav?
Or at least tried them?
Don`t know about yours, but my torsion bar carrier measures 90mm dia.
PostPosted: Fri Aug 21, 2009 8:36 pm    Post subject: Reply with quote
Ugh. No, not yet...
PostPosted: Fri Aug 21, 2009 10:04 pm    Post subject: Reply with quote
CORRECTION: Does not f*cking fit.
Grrrr, sh1t, bugger, f*ck.
9XX Girl!
PostPosted: Tue Jun 29, 2010 4:14 am    Post subject: Re: How to Install a Rear Sway Bar on a 924 without one Reply with quote
Chrenan wrote:
So..... does the exhaust have to come off or can you get the Anti-roll bar in position without removing the exhaust?
924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
924 (81) N/A 2 ltr - 3 Speed Auto - SURINAM RED (Metallic) - Near Original Spec (sticking with originality)
BOTH ON THE ROAD, BOTH USED EVERY-OTHER DAY
Rich H
PostPosted: Tue Jun 29, 2010 4:21 am    Post subject: Reply with quote
You can wrestle it into place OK with zorst on.
9XX Girl!
PostPosted: Tue Jun 29, 2010 4:26 am    Post subject: Reply with quote
Thanks mate
isuras2
PostPosted: Tue Jun 29, 2010 12:50 pm    Post subject: Reply with quote
Is it possible for the brackets be welded to the torsion tube with the tube mounted in the car?
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
Page 3 of 5
