ReMo
Posted: Mon Sep 22, 2008 9:53 pm Post subject: Venturi tube |
Hello i'm from the Netherlands so forgive me my poor englisch.
I still have a problem. The idle speed of my 924 2.0 ('81) was to high. The mechanic told me that in the venturi tube (petnr. 035-133-753-A) has to be something likes a piece of sponge. By my car that piece was missing so he gets to much air.
Can some one tell me if he is right?
He fixed it with a plastic cap with a little hole.
Martijnus
Posted: Mon Sep 22, 2008 10:25 pm Post subject: |
Haven't seen that thing before... where does it go? in the intake system? _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
ReMo
Posted: Mon Sep 22, 2008 10:30 pm Post subject: |
| It comes from the airfilter to the fuelhouse? en makes the vacuum on the brakes. |
Ozzie
Posted: Mon Sep 22, 2008 11:25 pm Post subject: |
Mine doesnt have a sponge and is straight through.
Make sure its the correct way around or it will affect brakes.
Too high idle is caused from timing, idle screw or air/fuel mix or combination of all 3. _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
Rich H
Posted: Tue Sep 23, 2008 1:57 am Post subject: |
I would think it will be a vacuum leak somewhere, could be there, but not likely, more likely to be the Auxliary air valve, one of the big rubber boots or injectro seals leaking air.
Martijnus: How are you working your brake servo with TBs? _________________ 1994 Lotus Esprit S4 - Work in progress...
Ozzie
Posted: Tue Sep 23, 2008 7:11 am Post subject: |
Any vacuum leak will mess with the air fuel mix. _________________ Porsche 924 1984 (UK import) NA
Martijnus
Posted: Tue Sep 23, 2008 7:31 am Post subject: |
| Rich H wrote: |
Martijnus: How are you working your brake servo with TBs? |
I use black magic to summon vacuum.
I've got an vacuum buffer, which gets its vacuum from the stock injector holes. So 4 plugs/leasds to this pvc plenum...from there, vacuum goes to MS, distributor, FPR and brake booster.
I could use vacuum from the gsx1000 tb's, or vacuum from just one cylinder...but I reasoned that 4 cylinders create the largest vacuum and hence it takes less time to suck the booster to a vacuum....
this way the engine could run a bit faster whilst idling...that's what I had before EFI... so I guess the booster's leaky or the car was running mega lean. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
Chrenan
Posted: Tue Sep 23, 2008 7:43 am Post subject: |
| Martijnus wrote: | | Rich H wrote: |
I've got an vacuum buffer, which gets its vacuum from the stock injector holes. So 4 plugs/leasds to this pvc plenum...from there, vacuum goes to MS, distributor, FPR and brake booster. |
Hmmmm, this is interesting. Any pictures or advice on where to get such a "vacuum buffer". Could it be used to provide vacuume to an ignition distributor when converting to carbs? _________________ 1987 951 - M193 Version for Japan |
ReMo
Posted: Tue Sep 23, 2008 5:16 pm Post subject: |
There are no leaks at all in the air/vacuum system. Yesterday i removed the plastic cap the mechanic placed. The car's idle is 1050 r/m.
I will ask if they can adjust the CO. The problems that i have is that the car will not start good enough. |
Martijnus
Posted: Wed Sep 24, 2008 12:38 am Post subject: |
| Chrenan wrote: | | Martijnus wrote: | | Rich H wrote: |
Hmmmm, this is interesting. Any pictures or advice on where to get such a "vacuum buffer". Could it be used to provide vacuume to an ignition distributor when converting to carbs? |
well... I got the idea from here, including pics (which are dead) ... it was mentioned in my "back on the road" topic... and came originally from msefi.com
it's just a pvc tube (sewer pipe... or sink drain or something) with end caps.
I'll look for a pic.
If you convert to carbs you could use this perfectly for the distributor... I do this too.
can't say if it works yet  _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
Chrenan
Posted: Wed Sep 24, 2008 12:45 am Post subject: |
Thanks for the info! Looking forward to any pics, I'll check msefi for some info too. _________________ 1987 951 - M193 Version for Japan |
Martijnus
Posted: Wed Sep 24, 2008 12:52 am Post subject: |
pics on msefi were dead iirc.
I was sure I had a pic of the seperate thing, but I guess I lost it during formatting my uberlame camera.
Found a pic with it still mounted on the engine, hope you get the idea:
the thing beneath the tb's. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
Chrenan
Posted: Wed Sep 24, 2008 1:02 am Post subject: |
OK, I think I understand.
1. Sealed tube below the throttle body intakes is the vacuum storage.
2. Hose running from each old injector hose to the vacuum storage to build vacuum.
3. Hoses running from the vacuum storage to whichever components nees vacuum.
Very neat!
Couple of questions.
What are the hoses connected to on the vacuum storage device? Are those just regular hose barbs or are they special?
Do you still run your brake booster directly off your intake manifold?
Any pictures of your injector holes handy to show the connections there?
Thanks Martijnus, don't go outside and take any pictures, just if you already have them handy. You should be resting and recovering. _________________ 1987 951 - M193 Version for Japan |
Martijnus
Posted: Wed Sep 24, 2008 1:13 am Post subject: |
hahah thanks
I just bought the cheapest hose barbs I could get, just regular barbs with NPT thread (iirc), the hoses themselves should have some margin for fitting tight.
The brake booster is fed from the storage plenum, because I don't have a manifold and I figured it was 'faster' when 4 cylinders would provide the vacuum instead of 1.
Plus, because it's on the same plenum as my MAP from megasquirt, MS should compensate for the brake booster air .
Still, I don't know if my idle will rise when I kick the brakes in.
I guessed about the volume, I was told some people use an old fuel filter for a plenum, fuel resistant etc...
I bought some other hose barbs, without threads, for the injector holes.. Keeping the rubber O-rings in the bungs provided a tight fit!
I guess I was lucky choosing the right barbs, but that's not that hard. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
Chrenan
Posted: Wed Sep 24, 2008 1:20 am Post subject: |
I like it! I'm hoping to finally put the new Weber kit I bought for my 924 a few years back on the car. I'm liking this vacuum idea, I could also run vacuum to my catch can as well. Lots of advantages. _________________ 1987 951 - M193 Version for Japan |
